Results 1 to 3 of 3
Thread: Boost controller + WMI info
    it's soo-tack sutyak's Avatar
    Fairmont, WV
    2,467
    Post Boost controller + WMI info
    I'm not sure how many turbo people we have on here who run water/meth injection, but I hope this info helps someone.
    For those who don't know, I have a turbocharged 2006 Focus. I used to have a 2003 Mach 1, and have been on SCS since the start. Major lurker now. :D
    (the story)
    Time for everyone to learn from my mistake/shortsightedness and possibly save a motor. Thank fully mine was not damaged.
    Last week I noticed the car was overboosting. It was set for 11psi, and running clearly uncontrolled somewhere over 15psi. I had recently tweaked with my boost controller settings, so I assumed that was the problem. Nope. There are only so many pieces that control boost, so I determined the issue was with the ball+spring in the boost controller Tee, also called the "gate".
    The ball had rusted badly enough that it was stuck in place. Since the ball+spring isn't even necessary I removed it to fix the problem.
    (the lesson)
    The cause of this is no doubt due to my running water/meth injection AND providing the boost signal to the boost controller from the intake manifold. Dumb. I was essentially blowing some water/meth into the boost controller every time it went into boost.
    I'm using a TurboSmart dual-stage boost controller, which is a bleeder style. This means that excessive boost will be bled off at the boost controller, effectively causing a small boost leak before the wastegate.
    (the fix)
    Option 1: Don't use that spring+ball, or at least replace the ball with one that won't rust
    Option 2: Use boost signal from before WMI is sprayed, if possible, so WMI is not forced through the boost controller
    Option 3: Use different style boost controller
    Option 4: Don't run WMI
    I'll be changing my boost controller signal from the manifold to the intercooler piping, and leaving out the spring+ball. For now I just removed the spring+ball.
    I hope this saves someone a motor. In hindsight I can't believe I didn't see this coming.
    2,483
    Thanks for the info. My meth isnt operating as of now (blowthru carb), have a grimspeed non bleeder hooked up at the turbo. Want to crank up the boost to about 16-18#s.
    Fairmont, WV
    2,467
    Quote Originally Posted by Silverhatch View Post
    Looking forward to seeing how it runs at 18#s! I have a built motor on the stand ready to go in, but the project has gotten pushed until Spring. Goal is 375-400whp, probably at 25psi.
  1. Which boost controller?
    By sutyak in forum Fox-SN95
    Last Post: 07-11-2012, 10:00 AM
  2. Wtb Boost controller
    By SK@StreetLethal in forum Ford Parts
    Last Post: 05-04-2010, 08:25 PM
  3. Aeromotive billet fuel pump controller
    Last Post: 05-10-2008, 01:16 AM
  4. AEM TRU-BOOST Controller
    By Viper_ed in forum General Tech
    Last Post: 10-09-2007, 04:01 PM
  5. PS2 games and controller
    By J-rod in forum Wanted
    Last Post: 10-19-2006, 09:17 AM
