Up for sale is a 1992 Ford Mustang LX that was being built to be a streetable race car. It’s close and doesn’t need much to complete whether you take it full race car or full street car. Some of the highlights of the build are :
PICS BELOW in thread
* 393 Windsor motor ( 351 stroked ) built by B&K Racing North Bloomfield, OH
· AFR 185cc aluminum heads
· Holly 770 Street Avenger carb
· Custom ground Comp cams camshaft .541 intake / .544 exhaust lift
· Edelbrock Performer lower intake
· 1.6 roller rockers
· Eagle rotating assembly / rods
· JE forged pistons
· 1 ¾” BBK long tube swap headers
· Custom built 3” x-pipe
· 3” dual Flowmaster 3-chamber 50 series Delta Flo mufflers / tailpipes
· Mickey Thompson Sportsman Pro tires on rear on factory Pony wheels
· 4.10 posi rear end
· C4 trans with 3800 stall speed convertor ( see below for description )
· B&M Pro Ratchet shifter
· Flaming River manual steering rack
· Upper / lower tubular rear control arms
· Switch panel ( electric water pump, electric fan, horn, tach, ignition )
· Bolt-in subframe connectors
· Interior includes front / rear seats, dash – no roll cage
· New PA state inspection
· 6” cowl induction hood
Extras that go with the car include :
· GT spoiler
· C4 transmission – was told it was a useable for parts – not certain on condition
Some of the items the car needs :
· Heater components and control panel have been removed – should be reinstalled if going the street car route – firewall NOT welded closed
· A/C components removed – should be reinstalled in street car
· Current C4 trans runs and shifts but slipsa bit and leaks fluid some times – extra C4 goes with the car
· Paint is presentable but needs a good wet sanding / buffing
· Power door locks are not hooked up
· Sub-frame connectors should be welded-in if going the full race car route
· Speedometer cable not hooked up
Steering shaft rubs on swap headers
Have most all receipts for build ( prior to my owning and since my owning ). Over $7,600 worth of receipts just in engine and exhaust. Asking $7,500
I can text or email you pics - can't upload them here. 724 552-6712. Thanks
