Results 1 to 6 of 6
Thread: Squeaking Noise - T5
    North Hills of Pittsburgh
    430
    I have an all-stock 94 Cobra with 42K miles that has developed a squeaking noise coming from the transmission area. It occurs when the clutch is disengaged at idle, in neutral, all gears, but it will go away by putting even the slightest amount of pressure on the clutch pedal.
    Is it possible the OEM clutch cable adjuster isn't allowing enough adjustment? I've tried pulling up on the pedal/OEM adjuster to adjust the clutch, but that doesn't seem to help or adjust anything.
    Any tips to help me solve this annoying noise are appreciated. Thanks.
    2016 GT Premium
    Hi Bob - I had this exact same issue with an '88 GT hatch years ago - probably was the summer of 1993. Replaced a weak clutch and saw some scoring on the T5's bearing retainer. I sold the car soon after so I never fixed it. Anyway, I think the scored bearing retainer surface didn't let the TOB slide/spin as it should, causing the squeaking noise. Later I learned that Ford started making steel bearing retainers to replace the factory aluminum pieces. The steel I guess is more durable than the aluminum. I'm sure other folks can give a more thorough answer, but my guess is the bearing retainer.
    I also tried the pedal adjustment trick but it didn't help my problem at all.
    Throw out brg.....try reaching down and grabbing the clutch pedal and pull up to put some preload on the brg. The ratchet and pawl mechanism will move a tooth.
    As John said, almost 100% the throw out bearing.
    Actually more common with some replacement ones from some manufacturers (for a while a lot of the ones Spec supplied did this).
    Administrator burntire's Avatar
    Pittsburgh, PA
    1,037
    I remember replacing a clutch and throwout bearing years ago. I had the squeak before and after the replacement.
    Out came the tranny again. It was the bearing retainer.
    http://www.latemodelrestoration.com/...aring-Retainer
    2016 Mustang GT
    430
    Thanks for the replies. I will try and pull up on the clutch pedal with my hand and get more adjustment. I am thinking the clutch cable has stretched or something.
    2016 GT Premium
  1. Replies: 6
    Last Post: 06-19-2011, 10:21 AM
  2. 96 noise
    By cwh19 in forum SN95-New Edge
    Last Post: 09-16-2009, 03:58 PM
  3. Ticking and squeaking
    By 95DropTop in forum Fox-SN95
    Last Post: 04-15-2009, 09:31 PM
  4. Weird belt squeaking sounding noise..
    By Jper in forum General Tech
    Last Post: 11-19-2008, 10:30 PM
  5. Tingling Noise
    By thehill63 in forum General Tech
    Last Post: 05-14-2008, 07:23 PM
