Like the title states, I am looking for a Teksid block for my latest project. Shoot me a pm if anyone has any leads on one in good shape. Thanks!
2003 Sonic Blue Cobra
-Under the knife this winter
I'm pretty sure the 93-98 Mark 8 used the same block as the 96-98 Cobras. The part number should be F6LZ-6010-AB.
I have heard that the early Mark 8 blocks were weaker, but I don't know how true that is. Is someone able to give insight on that?
Wouldn't an F6xxxx part number indicate a 1996 casting date?
Cx = 196x
Dx = 197x
Ex = 198x
Fx = 199x
I bet Ares can provide some input as he is building a nasty teksid motor for his car.
Could be - I just didn't want you think the '93 block wouldn't work just because it had a "3" in the second spot.
[QUOTE=Ares;356758]Pretty sure mine is out of a '95 Mark8. Can get pic of p/n later.
Edit:
Ok this is on outside of block. Cast in 10/94
Thanks. Are you aware of the early Teksid's being weaker or is this just a myth I've heard. I haven't been able to find any other block part numbers to compare.
[QUOTE=map22;356783]Honestly I never heard of that. Just avoid the Lincoln Continental Teksid. That is a front wheel drive setup and the block is different.
Also the aluminum WAP block. About 5 lbs lighter, not as strong but can be found in later Mountineer's and Explorers.
In my opinion if our not building a 1000hp engine I would spend the time and money looking for the strongest teksid block. They are getting hard to find and that is pushing the cost up.
Stock 03 Cobra Vroom Vroom!!
matt99 might have one, I'll text him and see.
