I would appreciate some help. Maybe if someone could check the timing and set it a 10, that might fix my overheating problem. I know the timing is off, so that definitely needs to be adjusted.
if it can wait til this weekend, i can come down and put it in a tooth the other way and set the timing and see what happens..
2014 RAM QUAD CAB 8SPD
nope, im up in gibsonia, remember meeting at the richland bar on rt 8..... i have no clue where hopewell is though
I took the rad cap off and topped off the rad. Started the car and let it run for like 15 minutes and really didn't have to add much antifreeze. The temp guage climbed up to the O in normal (see pic) basically at the line right by the O. Waited another 5 minutes, then put the cap back on and waited some more to see if it would drop. It didn't
i didn't realize the guy had pulled the distributor the entire way out? It very well could be off a tooth. Not trying to be a dick, but i'd not take my car there agian. No one should let their customer or friend roll out of their place running like that.
709RWHP/750RWTQ
why take out the dist. to change your t/stat? your tmi modular shouldnt be up against your intake, they usually point at the radiator cap direction.. if its pointing towards front of car then you are definatly out a tooth...
this will give you the turning radius you need for timing.. my .02
i agree either on timing or air pocket
you know, stores do sell faulty t/stats... just another option
This thing might be out 2 teeth. It takes alot to get it that far out. Its a simple fix to bring it back. Sounds like he was BSing you on making it right. It only takes a minute to lift the dist out and turn it to get it back in range. Wonder if he pulled the spout to set the timing?
The car was running fine and the temp was fine when I left on Sunday, so I am not sure what the problem is now?
He did have issue with the oil pump shaft coming out and trying to get it lined up again and then setting the distributor. Also the TMI module does hit the thermo housing on this cobra intake, limiting the area to be able to turn the distributor to set the timing.
Here is a shot of my engine. As you can see the TMI is right up against the t-stat housing. Should it be rotated more towards the right?
Don,
That distributor is WAY off. It must be off at least two teeth. I don't think that is your overheating problem. I think you have an air pocket in your cooling system. 5.0s are notorious for that.
its definately off a few teeth... but im skeptacle that it will fix the overheating problem as well
FWIW here is my motor shot the day i got it. stock Dist.
i need to get someone to bump my timing for me. :)
