Page 4 of 6 FirstFirst ... 23456 LastLast
Results 61 to 80 of 109
Thread: Overheating
  1. #61
    Member RUSH2112's Avatar
    Hopewell, PA
    754
    Why will it be trickier?
    I think it's in this thread, but the oil pump shaft will fall out when you lift the distributor to reset it 1 or 2 teeth. There's a possiblity of the shaft falling down into the oil pan. The guy who put my intake on removed the distributor 4 times and luckily the shaft didn't fall down the oil pan and he was able to retrieve it.
  2. #62
    Farmington WV
    4,672
    read this thread. lol and the one madmaxin22 posted from hardcore5.0. and look at the pic of rush's engine.
  3. #63
    Hopewell, PA
    754
    Pretty fubar huh
  4. #64
    Hopewell, PA
    754
    i believe that he did it then... odd situation... check the car out tonight and go from there
    Well, I thought I might have got it, but it is still acting up. Last night I took off the radiator cap, started the car and let it idle for 30 minutes straight to see if there was any air in it.
    In 30 mins the temp only reached 200 deg. That was a good sign. So I put the cap back on the radiator and figured I would take it out to see what happens. I didn't even make it out of my plan and it jumped up to about 250 deg.
    Oh well, Either the thermostat is frozen open, or my radiator is full of junk.
  5. #65
    Too many replies for me to read at work. If the car is running I doubt that it is off so bad the dist has to come out, just needs simple timing. A. I doubt your overheating that bad is from timing with the car just sitting there.
  6. #66
    Farmington WV
    4,672
    here is a pic of his motor...look at the distributor
  7. #67
    Hopewell, PA
    754
    Thanks for the input. I think I have help coming on Sunday
  8. #68
    Ahh. Wont advance any more. If the pump drive shaft does drop. I have a magnet!
  9. #69
    Member madmaxin22's Avatar
    on the red belt
    853
    if anything its stuck closed i would think.... the distributor is going to have to come out to try and fix the timing.... i'll be down sunday to hopefully straighten things out....
    2014 RAM QUAD CAB 8SPD
  10. #70
    Hopewell, PA
    754
    Thanks bro. Bring a magnet if you have one. I have a haynes and chilton manual. I will have the t-stat and gasket replaced on Saturday, along with the oil changed and a new oil filter.
  11. #71
    If it doesn't over heat with the car just sitting there that makes me think even more that it may have to do with the timing. The car just sitting still should be worst case senario for over heating. Then once you start putting the car under load the timing would come into play more. It needs to be fixed anyways so why not start there instead of wasting money on parts you might not need.
  12. #72
    on the red belt
    853
    it was fine on his 3 hour trip back this way the day of...
  13. #73
    Yes, but either way it needs to be fixed so why not just do that first to see if it works .
  14. #74
    Hopewell, PA
    754
    I appreciate you guys throwing ideas out there. 2 heads are better than 1 I am willing to try whatever yinz guys suggest
  15. #75
    on the red belt
    853
    thats what i plan to do.... i just dont think its related since the car isnt running poorly... just hot as balls.... could be an air pocket giving a bogus reading to the sensor though
  16. #76
    Hopewell, PA
    754
    I agree. but I ran the car at idle for 30 minutes last night with the rad cap off (i even timed it). I would sure think she would have burped or farted the air out by then. What else can I try?
  17. #77
    Hopewell, PA
    754
    madmaxin - did you get my other PM"s with my cell # and directions?
  18. #78
    Hopewell, PA
    754
    no bogus readings. Tuesday night when I got home, I let my dogs out and come back outside to see a huge puddle of coolant in the driveway. Turns out the overfill bottle was completely full and violently bubbling with coolant. The puddle was from the open bent escape tube. Must have come from the rad and boiled over into the overfill bottle. After letting it cool for 20 minutes, i came back out and the overfill bottle was almost empty (must have gone back into the rad)
  19. #79
    on the red belt
    853
    That sounds like HG to me....
  20. #80
    Hopewell, PA
    754
    FUDGE..... Is there a way to tell?
  1. 91 Fox Briefly Overheating before normal temp
    By Zoom50 in forum Fox-SN95
    Last Post: 04-21-2014, 06:58 AM
  2. Overheating - some help please....
    By SonofaBish in forum General Tech
    Last Post: 08-19-2011, 12:01 AM
  3. HELP!!!! Sometimes overheating....
    By 97LaserRed in forum SN95-New Edge
    Last Post: 02-15-2011, 06:27 PM
  4. Cobra is overheating! WTF!
    By Shadowstealth in forum SN95-New Edge
    Last Post: 06-02-2010, 09:46 PM
  5. 04 overheating
    By travj31 in forum General Tech
    Last Post: 05-03-2009, 10:53 PM
