Page 6 of 6 FirstFirst ... 456
Results 101 to 109 of 109
Thread: Overheating
  1. #101
    no seriously :)
    HGAHAHAHAHAHA You make me laugh. Stop up any time you like. I did rushes timing in about ten minutes. Set it once and then pulled the dist. and turned it 2 teeth to get it right. No problem.
  2. #102
    LowHill
    2,679
    My Dad had a similar problem with his 5.0 coupe and it was an air pocket in the cooling system. His t-stat housing had a fitting on it to burp it.
  3. #103
    Farmington WV
    4,672
    :( come down for the cruise tomorrow...ill buy your dinner
  4. #104
    Cant make it.
  5. #105
    Farmington WV
    4,672
    man you are being difficult
  6. #106
    Quote Originally Posted by lib88stang View Post
    His stat is working. The top hose is smoking hot and the lower hose is cool. I am leaning towards a bad or weak water pump. It is moving a little bit but not anywhere near what it should be moving. You can basically feel the stat open when holding the top hose. It gets real hot for a moment. The lower one stays warm at best. The impeller in the pump probally isnt up to par to flow enough coolant. Could be corroded. Its original.
  7. #107
    HAHA Loosen the 13mm bolt holding the dist down and turn it clockwise just a tad. That will do ya. At the end of the TFI module you will get about 1/4 to 3/8 of an inch. Thats it. That will put you at about 13-14 degrees advance.;)
  8. #108
    Member RUSH2112's Avatar
    Hopewell, PA
    754
    I appreciate everyone's support. The timing issue has been corrected. It was 2 teeth off and has been fixed and adjusted and set at 12 degrees. It is still running warmer than normal. The water pump is going to get replaced on Saturday (it is the ORIGINAL pump.... 14 years old and 150,000 miles) The pump is working, but we think it is just barely doing it's job.
    The pump will be replaced and the radiator is being removed and flushed out. Hopefully these 2 items will cure my temperature issue(s).
    On a side note, I was to thank WICK. What a super nice guy and he didn't have to stop out, but he did and got the timing fixed up pretty quickly.
    He even took the time to answer questions and explain how things worked and even my dumb a$$ could understand it.
    Edelbrock Performer Heads, BBK Ceramic Long Tube Headers, BBK O/R H-Pipe, BBK Cold Air Intake, BBK Strut Tower Brace, Flowmaster American Thunder Cat-Back, FRPP King Cobra Clutch, FRPP 3.73 Gears, FRPP Chrome Cobra Upper/Lower Intake, FRPP Chrome Polished Valve Covers, Chrome Alternator, Ford B303 Cam, Holley Fuel Pressure Regulator, 70mm Edelbrock TB, 75mm Pro-M MAF, #24 Ford Injectors, Crane 1.7 Rockers
  9. #109
    Farmington WV
    4,672
    wick is good at lending a helping hand to someone in need.
    i still owe him big from fixing my car.....we just need to get the fam's together for dinner one night.
    glad ya got the timing fixed
  1. 91 Fox Briefly Overheating before normal temp
    By Zoom50 in forum Fox-SN95
    Last Post: 04-21-2014, 07:58 AM
  2. Overheating - some help please....
    By SonofaBish in forum General Tech
    Last Post: 08-19-2011, 01:01 AM
  3. HELP!!!! Sometimes overheating....
    By 97LaserRed in forum SN95-New Edge
    Last Post: 02-15-2011, 07:27 PM
  4. Cobra is overheating! WTF!
    By Shadowstealth in forum SN95-New Edge
    Last Post: 06-02-2010, 10:46 PM
  5. 04 overheating
    By travj31 in forum General Tech
    Last Post: 05-03-2009, 11:53 PM
