Results 1 to 1 of 1
Thread: Mustang Wheels Fox SN95 5-lug Conversion Bullet
Threaded View
    Junior Member
    Nov 2012
    13
    If you have a Fox Mustang that you've converted to the SN95 5-lug, 4-wheel disc setup, this wheel/tire package will bolt right on.
    American Racing Authentic HotRod Torque Thrust M
    Fronts are a 17x8 (SN95 wheels) 30mm offset. 5.71 backspace. 20.8lbs. each. 5x4.5. 245/45/17 Nitto 555 tires.
    Rears are a 17x9 (S197 wheels) 45mm offset. 6.81 backspace. 21.6lbs. each. 5x4.5. 275/40/17 Nitto 555 tires.
    Cost new with lugs @ $1,300 w/out freight. Wheels/tires have around 500 miles on them. Never seen rain. Only caveat is the drivers front tire has some slices in it, when the metal tab at the front of the wheel well that holds the fender liner in was sticking out, and I didn't catch it in time. Ooopps. Including mounting hardware as well.
    Fronts will fit the Fox or the 94-04 Mustangs. Rears will fit Fox with 94-98 rear/axles with no mods required. To use these on Fox length axles, or on the 94-04 cars you'd need a .75" spacer.
    $900.
    I do have shipping available to me, but at this time, I'm not interested in shipping. If I still have them around April/May time, I will consider shipping.
    Located in the Pittsburgh region.
    PM me as I don't come in here that often. Thanks.
