Page 13 of 65 FirstFirst ... 311121314152363 ... LastLast
Results 241 to 260 of 1283
Thread: Proof that I blow thru more cars than Cam...
  1. #241
    Feb 2014
    397
    Quote Originally Posted by Tom View Post
    Can it do 9s on the stock trans?
    Can it get a single pass in the 9s? Most likely. Can it run consistently? Not in my opinion. At least not at full weight with factory turbos. The trans is limiting as is the factory turbos.
  2. #242
    2,145
    Quote Originally Posted by ERR0RMACR0 View Post
    I am trying to learn about these cars. Is the factory trans setup to protect itself from being over powered? I remember you saying something in a post about launching your car at the flds and having issues.
    Stock 03 Cobra Vroom Vroom!!
  3. #243
    If You Wanna thedak's Avatar
    Jul 2008
    DMB
    Yes.
  4. #244
    2,145
    Quote Originally Posted by thedak View Post
    Yes.
    That's impressive. I have to hand it to the people that designed these cars. Hey Ford pay attention.
  5. #245
    Senior Member Seer's Avatar
    Apr 2011
    800
    They do have a transmission that has run 9s and even 8s stock. It's called the 6r80.
    Now the 6r80 is an amazing automatic. It's still no dct.
    The tremec tr9007 seven speed dct that the ford gt has will also most likely be impressive.
    2022 BMW X4M Competition
    2019 McLaren 720S
  6. #246
    likes turbos Tom's Avatar
    Rostraver
    918
    Yes.
    That's pretty awesome how fast these cars get on the stock trans/turbos!
    1987 Fiero GT
  7. #247
    Jul 2008
    DMB
    I'll do upgraded factory turbos and a budget tranny build next Winter.
    Thats as far as I'm going with the car.
    After that the prices are even more outta me league.
  8. #248
    Feb 2014
    397
    The factory clutch assembly uses 7 friction plates and at the factory pressure, it begins slipping around 600tq. You can up the pressure to create more clamping on the 7 friction plates, but then you risk blowing the seals in the trans. Running a different transmission control module, can reduce the clutch engagement window, dropping temperatures, which allows for more clamping force--this could hold you around 600-650tq.
    Then the problem becomes running 9s with a 4,000lb (with driver) car with only 600 or so whp and tq. The factory turbos will make peak boost of around 22psi on ethanol, but that occurs at around 4k rpm--they bleed off boost to redline down to 15-16psi. When making a run, once the turbos peak boost in 1st gear, it bleeds down once you exceed for 4k rpm and the shifts never take you below 5,500 rpm therefore you're not seeing peak boost for the majority of the run (more importantly, the back half).
    The only way to overcome this is by either:
    A) replace the factory turbos with something that has a larger wheel to make more boost at higher RPMs or
    B) reduce weight
    Option B is an interesting proposition because not only will reducing weight make it easier for the said HP to move the car more quickly, but it also eases the stress on the transmission to clamp and pull the car out of the hole. This will keep the clutches cooler and more grip getting the most power to the ground.
    So in the end, a factory turbo, full weight, factory transmission GT-R will have a VERY difficult time pulling a 9 off. Maybe a hero pass at MIR one time, but certainly not consistently. Change any one of those 3 factors (factory turbo, full weight, or factory transmission), and it becomes a different discussion. Again, just my opinion and perspective from my testing experiences.
  9. #249
    2,145
    We have all said that. Just look at my car for an example. Oh a ported factory blower is all I need, lasted a few years. Oh this 2.2 kenne bell will be all I ever need, that didn't last as long as the ported eaton. Oh this turbo kit on a factory trans will work for me. Nope lets upgrade to a built th400. Oh the car cant hook up with the IRS, lets go to a built solid bla bla bla
    One secret us car guys know...Its never enough. We just cant stay happy unless we are building and going faster. The good news is that parts come down in price after time. That is the only way I can get some of the stuff I have.
  10. #250
    Jul 2008
    DMB
    Tablet Mount and goodies came.
    Turned out really nice.
  11. #251
    The BOSS GOT SVT's Avatar
    Cranberry Twp PA
    3,044
    looks good, nice job on the mods so far
    now it almost looks like your work car inside
    Current Stable
    1993 Red Cobra
    Previous Stable
    2012 White Mustang-Traded
    2003 Black Cobra-Traded
    1998 Black Cobra-Traded
    1991 White 5.0 Conv-Sold
  12. #252
    Jul 2008
    DMB
    I do like touch screens
  13. #253
    I hope you wash your fingers first...
  14. #254
    I Eat GTO's For Breakfast
    Claysville,Pa.
    41
    Matt car looks awesome good thing this car isn't as complicated as a vent less gas stove they need to put computers on them so it'll throw a code so you know what its doing.LOL
  15. #255
    2,145
    ERR0RMACR0, thanks for the info.
  16. #256
    Brighton Township
    1,665
    Quote Originally Posted by 2stangs View Post
    Hey Chuck you remembered how to get here?!
  17. #257
    Is your floor board bolted in good? With loc-tite? We don't wanna see it fly off in the 5 minute, I mean 10 sec pass it makes. Haha
  18. #258
    Jul 2008
    DMB
    Logged fuel trims at idle and cold start up when I got home.
    So much fun....
    F Winter...
  19. #259
    Feb 2014
    397
    Those pics looks great
  20. #260
    Yeah...that car is quite sweet. I'm glad mine aren't at home right now...this weather is depressing enough - I don't need to stare at the toys I can't play with!
