Results 1 to 4 of 4
Thread: pros and cons
    pros and cons
    i have an 88 lx body that i bought a late model fi 302 out of a bronco for now i know the harness is diferent so should i find the top end off of a 5.0 or should i go carb. which would be easiest and most cost eff. does anyone have any input?
    KB 2.6 custom fabbed
    Southern California
    311
    Carb will be cheaper for sure, however you have to deal switching to a non-return fuel system. If you want to make it mustang fuel injection you will need alot of stuff. If you find a donor car your golden, otherwise you will be spending alot.
    cool thanks for the info. so it wouldnt be just swap the intake?
    You could maybe get a return style fuel regulator with three ports on it and just use the stock fuel system. I've seen these used before, but I don't know if they would be able to regulate the pressure down low enough for the carb.
  1. pros/cons of using 31 spline t-lok from explorer???
    Last Post: 08-06-2009, 12:25 PM
  2. Pros And Cons On 410 Gears?
    Last Post: 08-06-2009, 08:20 AM
  3. throttlebody spacer pros and cons?
    Last Post: 07-04-2009, 11:51 PM
  4. pros and cons of a side exhaust?
    By Johnny B in forum General Tech
    Last Post: 12-06-2008, 12:01 PM
  5. anyone have these seats? pros an cons?
    By PunisherStang in forum The Bar
    Last Post: 08-15-2008, 12:00 AM
