Yep. I guess 19psi was the magic number for it to work loose, because it would hit 19 and start to "flutter" like the boost wasn't being held. Well the meth nozzle connector was lifting and causing a boost leak. If I let off and get back in it the boost would be smooth again right up to 19.
I was thinking spark blowout until I saw the nozzle.
So can you use the SRT boost leak fix for this (zip ties)?? :)
Zip-Tie love is strong in the DSM world too.
Username on here Dewayne's 1g DSM on the way to the 2013 Buschur Racing DSM/Evo/GT-R shootout in Norwalk.
Edit: Pre-Plastidip photo even!
Best MPH: 132.21
Best 60' 1.490
Just had a moment of inspriation: "Zip-Tie Mafia"
Well that 19psi stutter wasn't the meth connection. It happened on tonight's data logging, too. I'm guessing it's spark blowout, or my chinese blow off valve isn't holding. My new bov should be here in the next few days. I'd be surprised if it's the plugs, as they are only gapped to .035". A quick google search shows other cheap bovs that don't hold above 19psi.
A leaking blow off valve should cause a rich condition in a Maf car, as it would be a big ass boost leak.
Personally, I think your gap is too wide. My stock gap in the DSM is .028, and I usually run .024-.025. Closing the plug gap is free. Give it a shot.
Best MPH: 132.21
Best 60' 1.490
Good to hear the Torsen is worth the $$$.
Well I've been quiet because I ran into fueling issues, or I thought I had. It turns out the MAFia is pegging around 3.5v-3.6v, even though the MAF without it hits 4.5V+ fine.
I thought it was demanding too much fuel at 19psi, but the boost pressure had nothing to do with it, and the fuel pump duty cycle wasn't even 70%. The common factor was the MAF volts. After much reading it turns out another Duratec Focus owner ran into their MAFia pegging at 3.5V.
When using the MAFia the car felt like it hit a rev limiter around 3.5v MAF and 1.9 fuel pump flow. (I'm not sure what the fuel pump flow units are)
Today I removed the MAFia and ran it up to 4.5v and 2.3 fuel pump flow with no cutout.
I'll be ditching the MAFia and going with a wider range MAF sensor; either the SCT, Pro-M, or VMP. From what I've read they are all basically the same thing.
For now I'll stick to 12psi until I get the MAF situation worked out. It's already in a 3" MAF housing and is basically pegged at 12psi.
On a positive note I got the MAP sensor input to the XCal2 working. To share a dumb moment, I originally hooked it up to the same boost line as the boost controller, which is a bleeder valve style. Well of course it never read correctly since the pressure in that line was never what it was in the intake manifold! I finally picked up some more hose Ts and hooked it up with the meth controller.
This type of boost controller certainly spikes before settling.
The BIG thing I'm glad about in this chart is the violet line which is the Fuel Pump Flow Rate. It reach a new max after removing the MAFia. MAF counts here got up to 905, but it's not on this chart.
yellow = boost (12.7psi spike settled to 11.5psi)
blue = AFR
greenish/orange? = load
grey? = rpm
Yes I'm colorblind...
Is it possible to max out the maf sensor before it gets scaled by the mafia? So if you hit 15psi and its 7v on the maf, but it can only do 7v total, then the mafia (@50%) would be stuck at 3.5v on anything above 15psi.
Did it scale right at lower psi?
1987 Fiero GT
I think that explanation would defeat the purpose of the MAFia; if the MAFia couldn't prevent the MAF from pegging then there is no point using it.
It scaled up to 3.5v, regardless of PSI and setting.
So I was able to crank the boost up to 19psi on setting "3" on the MAFia, but it still pegged at 3.5v. So technically I could keep cranking the MAFia settings up and live within the 0-3.5v range, but then my overall resolution goes to crap and I'd probably have to set my idle around 1300 RPM just to stay in range. The MAFia has settings from 0-8 I believe.
Without MAFia, I (nearly) max out the stock MAF at 12psi and 6500 RPM. No fuel cut. MAF at 4.5v.
MAFia setting 2, maxed out at 12psi and 6000 RPM. Fuel cut. Scaled MAF at 3.5v.
MAFia setting 3, maxed out at 15psi and 5500 RPM, or 19psi at 5000 RPM. Fuel cut. Scaled MAF at 3.5v.
This page has the correct scaling of the sensor.
https://www.diablosport.com/products/mafia.html
Don't know what that particularly means, as I ditched my maf long ago and went to speed density.
Edit:
this might help more.
https://www.diablosport.com/manualFi...structions.pdf
You have to adjust your tune based on what scaling you use on the MAFiA
Best MPH: 132.21
Best 60' 1.490
