I can't find anything on a 3082r.... What are the turbine dimensions? That really looks like a 3582hta to me.
Best MPH: 132.21
Best 60' 1.490
It's a 3082R, not a 3582R. The 3082R is an extremely rare bastard turbo that people either seem to love or hate. It is also from HTA, so you got that part correct.
Here is the tag number, but even that comes up as a 3076R. I did measure the compressor exducer at 82mm. I did not measure the turbine.
"HTA" is just a fancy nomenclature for some extended tip billet goodness.
If it is really a 30r turbine, you should see full boost well before 5k rpm. I see full boost around 4700 on a 35r sized turbine. Of course, I think the 4g63 head flows a bit better than the focus head, and my cams are quite a bit more aggressive than the specs you listed, so that all affects that stuff. Should be interesting to see the results.
Best MPH: 132.21
Best 60' 1.490
Thanks. I'll learn all the nomenclature someday.
A quick google search looks like the 4g63 head and Duratec Focus head are actually very similar in flow! It's tough to find a base flow for the 2.0 Duratec, but a mild port flows 330cfm at .5" lift. My head has no work done to it and cam lift is just .38".
For those interested, ARP does make flywheel bots for the Duratec. This would be the 2.3, or any single-mass flywheel. That means they would be too short for the stock 2.0 flywheel.
These are FAR better than the junk from Ford. The heads are a beefy 19mm vs the 11mm from Ford that want to strip on every turn.
Gah. I finally found it. That's why I didn't recognize it. The 3082R is generally referred to as the GT3040r.
Its basically a 35r compressor on a 30r turbine. Spools a little slower than a 30r, a little more power than a 30r. Should be good for about 55-56 lbs/min or so. I'd guess spool would be in the 4200 range or so.
Best MPH: 132.21
Best 60' 1.490
Depends on which exhaust housing you have, but I'd say 60 is possible on kill... All depends on how hard your setup let's you push it.
Best MPH: 132.21
Best 60' 1.490
Looks like this track rental is going to be very interesting :)
Best MPH: 132.21
Best 60' 1.490
that wastegate you got is pure sex! Lookin' awesome!
I have an rfl blow off....it is almost obnoxious, lol
Just a little 500 whp V6
Lol. My Chinese one was an sqv style, whatever that is. It came with a plastic tri-star piece that made it sound like someone stomped on a mouse between shifts. I took the plastic squeaker out after a week.
I think the JGS will just sound like a rush of air, which is perfect.
While waiting on some parts to arrive in the mail I was able to get the H&R setup installed yesterday. I believe about all of the struts and shocks for the Ford Racing suspension were shot and leaking after only 40K miles or so. I think the dampers they paired with the springs were a poor combination. The H&R springs/dampers I bought were used, but still in great shape except for the strut mount bearings, so I swapped in the ones from the other setup. The Steeda rear sway bar is a monster compared to stock. I'm hoping it helps even out the rear, as this car tends to seriously understeer and then "wag" when coming out of a curve hard.
I believe this is the correct spring rates (lb/in):
Stock: F 110, R 117
Ford Racing: F 129, R 157
H&R: coilover F 370-460, (race) R 375
I mainly wanted the stiff rear springs to prevent squat on launch at the track. The front coilovers I wanted so I could adjust the height and lessen the rub of the 235 tires.
The rear sway bar is much heavier than the stock, but the coilovers are lighter aluminum instead of the steel struts as before, so I think the difference is made up. The car will also drop a few pounds losing the cat, and changing from some steel piping to aluminum or plastic.
Here is another shortcut I took to get the car done sooner than later. I bought a 4" flexible inlet pipe instead of fabricating one. This way the only thing I had to fabricate was a small bracket on the battery tray to hold the air filter in place. The 4" turbo inlet makes for some extremely tight fitment.
