Page 14 of 14 FirstFirst ... 4121314
Results 261 to 273 of 273
Thread: sutyak's turbo focus
  1. #261
    it's soo-tack sutyak's Avatar
    Fairmont, WV
    2,467
    when does the echo get a turbo kit? :)
    Rule #1 of a happy gear head marriage: don't mod the wife's car.
    Rule #2 make sure wife's car is running before modding own car.
    mark
  2. #262
    True story bro...
  3. #263
    Brookline
    2,897
    Quote Originally Posted by sutyak View Post
    #realtalk
  4. #264
    3,316
    you have a point! :)
  5. #265
    Fairmont, WV
    2,467
    I got a day to work on my car. First thing I needed to refurb my vise, as it has taken a lot of abuse over the years. After that I got the wastegat return plumbed back into the downpipe. I'm definitely looking forward to hearing the turbo again and not just the loud wastegate dump.
    I used a Vibrant v-band flange for the dump return, and man is it nice! The two parts have matching machined male and female rings so they positively mate perfectly every time. That helped tremendously keeping a handful of unjoined parts lined up. I also used a Vibrant "bellows" style flex pipe; also a beautiful piece. Way better quality than the typical braided liner. I picked both up from a turbo group on facebook for cheap. I'm not sure I'd shell out the $ to buy them directly from Vibrant. Both are pretty expensive!
    I also got the 3" inlet mocked up. The 4" flex hose is no more. Now it is 3" aluminum pipe. I just need to secure it some way then that will be done. Only the hot side intercooler pipe is left.
    mark
  6. #266
    Lookin' good!!
  7. #267
    25 in the 1/4 SlowSix's Avatar
    Nov 2010
    Greensburg
    1,309
    I have a couple vibrant v bands that I got from summit. They are pretty nice. Looks good.
    Open dump pipe ftw though
    Just a little 500 whp V6
  8. #268
    U.S. Citizen 86GT's Avatar
    Sep 2011
    Monroeville
    323
    I'm looking forward to seeing your Focus ripping down the track at
    PRP in some good cool & dry air.
    Lil' Blackie, also a Rodeheaver hot rod
    Black Bess : n/a 347 T56 magnum,426 hp/ 427 tq
    Best time at Keystone 11.68, best speed 122.95 mph (right lane)
    Built, tuned & made possible by Tim Rodeheaver
    Rodeheaver's Hot Rod Shop
    15 W. Cross Ave.
    Masontown Pa. 15461
    724-737-5088
    www.RodeheaversHotRod.com
  9. #269
    3,316
    I love living boosted life vicariously through this build.
    I've had a change of plans for myself and I'm on the lookout for a pair of GTX3071Rs. If you have any laying around let me know! :)
  10. #270
    Fairmont, WV
    2,467
    The GTX2871R is on and running. I determined I need to put a stronger spring in the BOV due to lean bogs between shifts. With the BOV unhooked (always closed) it doesn't happen at all.
    The boost comes on smooth and fast with the new turbo. It's a surprisingly quiet. Quieter than the previous garrett GT2871R I had on before. On just the 17psi wastegate the 235's spin easily.
    Even though the Focus is for sale, I still plan on driving it and racing it if I get the chance. I certainly haven't lost the love for the car. It's still a blast to drive!
    mark
  11. #271
    Junior Member
    Aug 2015
    3
    Thanks. It's been a long project over the past 8 years with many different configurations. I'm trying to squeeze as much enjoyment as I can out of this little car. Everything I can do with this to keep myself entertained keeps me from dropping a ton of cash on a new project car, which would probably be a '10-'14 GT500 or '15GT.
    he pistons, the rods, the rings, the fuel injectors, the ecu, your o2 sensor, intake, exhaust, make sure that the turbo kit comes with all the piping you need for the intercooler. If you're looking at a kit from eBay, it does NOT have the parts you need.
    Might also need an upgraded fuel pump. May be other things.
    The engine isn't designed for turbo use...so, you need to make it that way.
  12. #272
    Fairmont, WV
    2,467
    Quote Originally Posted by AnSmith View Post
    Spammer...
    mark
  13. #273
    Fairmont, WV
    2,467
    The Focus is running great with the GTX2871R. It personally think it's a perfect match for this 2.0L. I love having my lower RPM spool back. Full boost by 4K and pulls like a monster to 7K. I haven't run it over 7K yet, but the data logs suggest it would continue to flow. I also believe my spark issue is gone; fixed by the colder plugs.
    The car is for sale, but I'm going to continue to enjoy it while I have it. If nobody buys it I won't be heartbroken, but it would be nice to have the space in my garage. I'll probably sell the Mustang if I can't sell the Focus.
    I hope to head back to the drag strip this weekend or next.
    A few new photos
    One with my buddy's Fusion at church. (Not staged. He doesn't even know I took it.)
    A few videos of the car.
    mark
