Page 1 of 14 12311 ... LastLast
Results 1 to 20 of 273
Thread: sutyak's turbo focus
    it's soo-tack sutyak's Avatar
    Fairmont, WV
    2,467
    For a quick history, this is the car that brought me to SCS:
    After a couple years having a blast with it, racking up well over 100 1/4 mile passes (best of 12.65) I sold the Mach 1 and picked up a new 2006 Focus 5 door. You know, doing the responsible thing...
    I do miss the Mach 1 and might have to buy another one someday.
    It didn't take long to start playing with the Focus, but I didn't mess around. I skipped all the cold air intake junk and went straight to a turbo. Don't mind the external links. They are some extensive reads.
    Nearly EVERY piece of this car was built my me, from the motor to fabricating the turbo manifold, intercooler piping, and full exhaust.
    Build #1 (2007): Stock motor with custom Thunderbird IHI turbo
    Build #1b: Upgraded IHI turbo to a hybrid
    Build #2 (2012): Upgraded turbo to GT2871r. Switched to external wastegate.
    Current build (external site with many more details)
    My PhotoBucket site with all the photos.
    Build #3, Current build:
    Same GT2871r
    SuperTech 10.4:1 pistons
    SuperTech rings
    Forged H-beam rods
    ARP head and main studs
    Clevite main and rod bearings
    Crower valve springs and retainers
    Crane stage 1 cams
    Exedy Hyper Single clutch
    Torsen LSD
    15x8 Weld wheels with 24.5x8 MT slicks
    More Prothane suspension bushings
    Coilovers? Have them. Not sure if I'll install.
    Steeda rear sway bar. Also not sure if I want the extra weight.
    Possibly partial new exhaust
    Aluminum steering rack bushings
    Delrin motor mount bushings?
    Extended wheel studs for front wheels
    Direct port methanol injection with progressive controller
    Dual stage boost controller
    Kenne Bell boost-a-pump
    Lakewood traction bars
    Braided brake lines
    Non-performance:
    SVT Recaro leather seats front and back
    SVT side mirrors
    MAP sensor for data logging
    Goal: 375whp+ and 11.9 sec 1/4 mile
    The motor I'm building is the original out of my car. It suffered an overboost with the IHI turbo and damaged/broke a ring landing and began smoking like crazy. This happened a few years ago, but I'm just now getting around to rebuilding the motor. This is my first ground-up rebuild. With the exception of some very minor scratches (can't even feel it with a fingernail) the motor was fine and fully rebuild-able.
    Since this motor had no significant damage and very low mileage I'm lucky enough to not need anything professionally machined. That being said I'm still measuring everything and comparing against the Haynes manual.
    The cylinders were a bit shiny and I wanted to get that small scratch out of cylinder #2 so I used a 3-blade 220 grit hone to give it a new cross-hatch. I did as little honing as possible and stayed with the 87.5mm pistons.
    Following SuperTech's formulas I gapped the top ring to .018" and the second ring I left at .023" as it came out of the box.
    The valve springs and retainers are upgraded with Crowers. I went with steel retainers vs. titanium after speaking with a representative at Crower regarding street vs. track use. The steel are also significantly cheaper.
    I'll be using a TurboSmart dual-stage boost controller, with a toggle switch for the second stage. First stage will probably be around 13-15psi, and second 20-24psi.
    The motor is built, in the car, and has the first 80 or so break-in miles. I'm currently finishing up an extensive wiring project to install the heated/power seats, MAP sensor, USB ports, meth controller, BAP, various relays, and boost controller. Soon it will be back on the street. After about 250 break-in miles I'll start ripping on it and getting the tune worked out.
    Torsen
    New clutch
    Mocking up the meth nozzles
    Checking cam lobe clearances
    Motor shot
    As it sits now with the winter wheels
    And the turbo
    Fairmont, WV
    2,467
    How it looks at the moment
    Methanol controller, because race cars don't need to hold CDs.
    BAP
    Basically how it looks now. Wiring is nearly complete.
    Feb 2014
    397
    Awesome build, man--looks like you put a lot of work into get everything put together. Looking forward to hearing some numbers on this :)
    Fairmont, WV
    2,467
    Quote Originally Posted by ERR0RMACR0 View Post
    Thanks. It's been a long project over the past 8 years with many different configurations. I'm trying to squeeze as much enjoyment as I can out of this little car. Everything I can do with this to keep myself entertained keeps me from dropping a ton of cash on a new project car, which would probably be a '10-'14 GT500 or '15GT.
    Jan 2010
    170
    Nice car! Awesome seeing a build out of the mainstream
    Nov 2010
    Greensburg
    1,309
    love it. I love builds that aren't your typical stuff. Any idea what the car weighs?
    Just a little 500 whp V6
    Fairmont, WV
    2,467
    Stock it was 2650lbs according to Ford. I haven't weighed it since then, but no doubt I've added weight from the intercooler pipes and 3" turbo back exhaust. The leather power seats certainly won't help. I'd figure 2750-2800lbs now. Race weight without seats, spare, and my 160lbs self would still be at least 2800lbs. For the track I'm heavily considering a straight dump after the crossmember. That will save weight and help spool.
    On my to-do list is to buy a TIG welder this year and start working with aluminum. The first project will be aluminum intercooler piping instead of stainless steel, and possibly a full aluminum exhaust.
    Nov 2010
    Greensburg
    1,309
    pretty light. Aluminum intercooler piping would definitely help. Never heard of anyone doing an aluminum exhaust though.
    Fairmont, WV
    2,467
    I agree it's rare, but it's certainly done. I doubt I'll go to that expense when I can just dump it at the track. Another Focus owner with a 600hp build did a 4" turbo back aluminum exhaust, which is where I got the idea.
    Nov 2010
    Greensburg
    1,309
    interesting. There is a guy on moddedmustangs with a turbo focus. Not sure how fast it is though. are you running pump gas or e85 ?
    Fairmont, WV
    2,467
    Pump (91 or 93) plus 50/50 water/methanol injection (4x 1.5gph nozzles). I'll be tuning without the WMI initially so I can really see how much timing I can add with the WMI. With 10.4:1 compression and up to 24psi, I'm assuming the WMI will be necessary. I built the motor expecting to run WMI.
    Cool project man! Good luck with everything!
    very cool project i would love to have a turbo on my focus
    Fairmont, WV
    2,467
    Thanks guys. I'm hoping for a 11.9 run this year after I get used to launching a FWD and tweak the suspension and traction bars. A track rental would be ideal where I could make adjustments at the track and get more than two runs in.
    If anyone hears of a track rental at PRP, Mason Dixon, or Quaker City (I guess Quaker City is still around?) let me know!
    likes turbos Tom's Avatar
    Rostraver
    918
    Get that focus some medicine, it's going to be sick!
    I can't wait to see it run.
    1987 Fiero GT
    3,316
    unequivocally some of the best sport compact turbo porn i've seen in a while! I might be taking up an offer to get a focus wagon and I would be hard pressed not to follow in your footsteps lol! :)
    robinson
    1,091
    awesome build. Been building aluminum exhaust for a while. I have a 4 inch downpipe back out fo aluminum and weighs 9 lbs. well worth the effort for weight reduction. have built a few others with good results too and several thousand miles on them
    /twocents
    Fairmont, WV
    2,467
    Thanks! It's been a fun build. I can definitely overwhelm you with turbo Focus information if you do pick one up to play with. While cheaper than a lot of cars to modify, it's still been a money pit.
    3,316
    right on... im going to swing a PM your way with a question
    Senior Member Cam99's Avatar
    Melcroft
    4,178
    Sweet build!
