Results 1 to 18 of 18
Thread: FLDs top street what is it going to take
    2,145
    Not sure if they will have the classes this season, just using the reference to classify the type of car. So with all the new builds going on what is it going to take to be the fastest street car? I am not talking tube frame gutted out race cars playing street. I am talking full factory interior, glass, alternator, heat ac, power brake and steering, hot lapping cars. Heck you can add in pump gas if you want. I just know some will be E85 so I am not sure where that puts the car. I don't have any up here, I can only get it delivered. Post up your opinions.
    Stock 03 Cobra Vroom Vroom!!
    likes turbos Tom's Avatar
    Rostraver
    918
    It will definitely be under a 6 second 1/8th car. I hope they do the street class again this year, it makes it more entertaining.
    1987 Fiero GT
    Feb 2014
    397
    I run ethanol for a variety of reasons--my car can also run on pump gas without draining the tank or anything, so it makes it so easy to run it. I simply pump it in if they have it at a station, and if not, I pump 93.
    Cars that require draining the tanks and all of that business, I'm not sure...everyone has a different opinion on it. Under 6 in the 1/8 is likely an 8 second car. I've never seen a car that fits Ruthless' definition run an 8 at my track, but they most definitely exist.
    Curious to see what makes it out this year and fast everyone is.
    Rostraver
    918
    Quote Originally Posted by ERR0RMACR0 View Post
    I'm mistaken, I actually thought 9 second cars were under 6s, since my car was in the 6s at a 10.7. It must be the weight making the first 1/8th a bit lower on mine.
    1987 Fiero GT
    Viral but not contagious. RedRocketVette's Avatar
    Feb 2015
    40
    The Chevette is 100% chevette aside from the rear axle, trans, and engine haha. "Imma street caaaar."
    Oct 2010
    Carmichaels
    219
    Quote Originally Posted by Tom View Post
    Depends on the build. My 1/4 was 11.6 and my 1/8 is 6.9
    Nov 2010
    Greensburg
    1,309
    Awd.
    Just a little 500 whp V6
    Feb 2015
    40
    I'll be on pump gas with methanol injection, and it'll be driven to and from the track without any adjustments. I'm not sure how much boost I'll be able to run off the line but I'm footbraking it only so it should be soft enough that I don't spin too bad. I'd like to see what else is running there, I'be never been to a FLD event so I'm not sure what to expect in terms of fast "street" cars.
    Feb 2014
    397
    Quote Originally Posted by RedRocketVette View Post
    Can't wait to see your car run
    Feb 2015
    40
    Same here! I keep breaking it before I go to the track.
    You will need a low 6sec car that hooks. The yellow cuda gave me a good run.
    1969 Camaro restomod/project
    1967 camaro
    2011 mustang procharged
    93 reef blue notch blk/int
    92 calypso notch blk/int
    86 t-type
    1972 chevelle project
    2,145
    Quote Originally Posted by went9s View Post
    You will need a low 6sec car that hooks. The yellow cuda and gave me a good run.
    I am not familiar with a yellow cuba. Do you have any vids of the runs?
    Ill look
    1967 camaro
    86 t-type
    1967 camaro
    86 t-type
    Feb 2015
    40
    I want a piece of that fish.
    2,145
    ^ Not sure I have seen that Cuda in person but I will keep any eye out.
    That Cuda rips...but I haven't seen it for 5-6 years.
    ...yeah...I don't get out much...
    Feb 2014
    397
    I'm not sure if I've ever seen it run--looks mean as hell though lol
