Results 1 to 14 of 14
Thread: Coyote Stock Block Power Levels
    3,316
    I've done a ton of googling and found a bunch of info dealing with aluminator short blocks or stock short blocks, but nothing on the stock block itself.
    I'm trying to plan my "pay to play" route over the next 18 months or so. I'd *like* to crack 1000 at the wheels but I think 800 is going to be far more realistic. As many of you know Ford/FRPP offers two blocks: the standard '13-'14 production block (M-6010-M504V) and their coyote performance aluminum block (M-6010-M50R) which is reinforced in key areas for "high horsepower builds". The thing is everyone has a different definition of "high horsepower" and my google fu has not provided a definitive answer on the realistic limits of the production block.
    Is it unrealistic to expect the production block to hold up to 800-1000whp/600-800wtq levels? What sort of power levels/boost pressures mandate the performance block?
    Links to references would be appreciated. I didn't find anything definitive.
    2,145
    Much more to making power and keeping the car reliable at those power levels then the block.
    Stock 03 Cobra Vroom Vroom!!
    fairmont,WV
    1,352
    Ken Bjonnes just blew his stock block/built auto TT car that ran several 9 sec passes. He works for Lund Racing and is the other tuner besides John. He has had this car for a couple years and daily drove it quite a bit. So I would say you power level is sustainable going by Ken
    XXX RWHP
    XXX RWTQ
    3,316
    Quote Originally Posted by RUTHLESS View Post
    agreed, but I don't want to the block to be a weak link after spending good money for forged internals and a billet oil accessories.
    3,316
    Quote Originally Posted by no1sirbutler View Post
    Good to know. Thanks!
    fairmont,WV
    1,352
    Oh you a stock bare block......if you are buying forged internals you will be good to go well past your goal. Kens detroyed a piston which took out the block. His was a completely stock block including internals
    XXX RWHP
    XXX RWTQ
    On the down low cam303's Avatar
    978
    Sleeve the block then no worries.
    3,316
    Yes just the bare block itself, not the rotating assembly.
    Quote Originally Posted by cam303 View Post
    doesn't it come with some kind of sleeve from the factory?
    RRT juice_man_86's Avatar
    Uniontown, PA
    533
    Talk to Tim at Rodeheaver 's Hotrod. There's a 14 down there right now. He built it. It's got a Hellion twin turbo kit making north of 800 rwhp. Not sure, but they may be shooting for more.
    2014 Mustang GT m6 - 12.97@111
    All stock down to the tires
    12.53 on slicks. Stock. No tune.
    1986 Mustang 5 speed - 12.10@110 off the sauce
    11.05 on Nitrous babying a hurt t-5
    327 stroker BOSS block with junk Pro Comp heads
    355hp n/a
    520hp on nitrous
    All Nitrous parts are gone. Turbo on the way
    Tuned by Tim @ Rodeheavers Hotrod & Dyno Shop
    So far we have made 800 wheel with a stick block coyote. Not stock Pistons orchids but stock block n crank. The clutch could not hold it so we just got done putting a stronger clutch in the car but have to break it in yet.
    2,145
    The factory applies a coating but its not a pressed in sleeve. The big boys use iron sleeves to add strength. It's recommended when you go over 1000hp.
    3,316
    Are you sure? Now Im really confused...
    http://www.americanmuscle.com/frpp-a...tblock-13.html
    Features
    Coyote 5.0L block (302 cubic inches)
    Low pressure cast 319 aluminum
    92.2 mm bore size
    Thicker main webs for added strength
    Cross-bolted nodular iron main bearing caps
    Pressed in iron cylinder sleeve, is not machined for piston oil squirters
    Ford Racing part# M-6010-M504V
    2013-2014 5.0L production block
    Senior Member Seer's Avatar
    Apr 2011
    800
    The production 2011-2015 block is good for about 1000hp, the FRPP Sportsman coyote block can make much much higher. The production 2011-2014 short block can safely make into the 700s before getting on borrowed time. The 2015 shares a similar bottom end with the Boss 302 and has shown to make into the 800s safely. Upgrading the oil pump gear to a billet setup is always a great mod to do, and greatly increases it's life span while under forced induction.
    2022 BMW M4 Competition xDrive
    2022 BMW X4M Competition
    2020 Ford Mustang Shelby GT500 CFTP
    2019 McLaren 720S
    3,316
    thanks for the input everyone. This helped me allocate funds where I think they will do the most good for the power levels I want to attain.
