Page 7 of 12 FirstFirst ... 56789 ... LastLast
Results 121 to 140 of 230
Thread: EM's GT-R Refresh
  1. #121
    Feb 2014
    397
    Quote Originally Posted by Tom View Post
    Are you mixxing the e85 and 93? The lowest its supposed to ever be is E70 according to the pumps. I may have made a mistake switching my setup to e85...
    Straight from the pump, mine was reading e67. Dak's will likely go up in ethanol content once he runs a tank or two through to get that nasty pump gas out of there lol
    Welcome to the ethanol team. Your engine, turbos, etc. thank you for your coorperation :)
  2. #122
    likes turbos Tom's Avatar
    Rostraver
    918
    Quote Originally Posted by ERR0RMACR0 View Post
    The v6 turbo ethanol club!
    I would be ok with e67, my car isn't as smart as a gtr and would run way to rich on e50.
    My plan is to have it run e70 a little bit rich, so that when it gets into e85 it will lean out.
    1987 Fiero GT
  3. #123
    Rostraver
    918
    Summer Blend: Class 1 (min 79% ethanol)
    Spring/Fall Blend: Class 2 (min 74% ethanol)
    Winter Blend: Class 3 (min 70% ethanol)
    Lake Arthur is around 41 deg. latitude.
    1987 Fiero GT
  4. #124
    Senior Member Dan B.'s Avatar
    Armagh, PA
    4,331
    Ahh fuque
    1986 Ranger--2WD, 5.0/T5/8.8.
  5. #125
    Feb 2014
    397
    Luckily, we're south of 41, so we get to keep blend 1 for an extra month :)
    Thanks for posting this, I'm sure the non-ethanol crowd was wondering what the hell I was talking about lol
  6. #126
    Rostraver
    918
    PA is looking out for SCMC
    I never realized that there were different blends until I started looking into it for my car.
    1987 Fiero GT
  7. #127
    How do you test your fuel? Just curious thanks
  8. #128
    Feb 2014
    397
    Quote Originally Posted by pwtmxracing View Post
    Most flex fuel kits for our platform run the GM flex fuel sensor and a digital display is installed in the battery compartment. When filling up, I check my oil, and then the gauge with the primary pump priming (return style fuel system) to see the ethanol content.
  9. #129
    that's some hi tech shit right there. I just have a quick fuel e85 tester...
  10. #130
    Feb 2015
    904
    I am assuming your tune automatically corrects for the ethanol percentage in the fuel?
    Best MPH: 132.21
    Best 60' 1.490
  11. #131
    2,145
    Good lord I am just going to pick up a drum of fuel when push it that far. I cant be constantly messing with tunes and crap. I just wana go fast!
    Stock 03 Cobra Vroom Vroom!!
  12. #132
    Feb 2015
    904
    Some of the flex fuel stuff (even the one I can get for my dinosaur) have the capability of being TRUELY flex fuel, and will adjust the tune accordingly. I assume the GTR's flex fuel stuff does this, but am not certain.
    Best MPH: 132.21
    Best 60' 1.490
  13. #133
    My car got a carb all I do is check that crap before I fill my cans and away I go.
  14. #134
    Feb 2014
    397
    That is correct. The tune automatically adjusts several parameters depending on the % of ethanol currently being run.
  15. #135
    2,145
    I am just going to let you guys play with this stuff.
    https://youtu.be/8DZhLjwsWVY
  16. #136
    Sweet I'm sticking to my shitty glass tube to measure mine..
  17. #137
    Feb 2014
    397
    Wow, really interesting--thanks for sharing. There's an assumption baked in that whatever is not gasoline must be ethanol rather than measuring the ethanol and assuming what is not is gasoline.
    Hm, interesting tid bit, but I don't think it really changes the outcome by it being the inverse, right? If there's water in it, whether you measure the ethanol or the gasoline, there an assumption that the other product is the opposite.
    With test tubes, would it tell you that there is water?
  18. #138
    With the test tube you use water to check it.There is a fill line for water then you add fuel to a certain line and the water will separate from the fuel and it has marks from 70% to 100% and where ever that line of separation is is what percentage the fuel is ethanol.
  19. #139
    Feb 2014
    397
    Thank you for the explanation. So water separates from the fuel, however, how do you tell the difference between gas content and ethanol? Sorry if I missed something.
  20. #140
    That's a good question.
