All it is, is a graded tube, that tests ethanol content from the pump. You fill the water to the water fill line, then the rest with "E85" when it separates it tells you what real percentage of ethanol is coming from the pump. If it's E85, it'll show 85%
2022 BMW M4 Competition xDrive
2022 BMW X4M Competition
2020 Ford Mustang Shelby GT500 CFTP
2019 McLaren 720S
My car will just make whatever it makes on pump and I'm calling it a day. That is if I ever build a motor atleast.
Plus the closest e85 station to me is I believe 35-40 minutes
Just a little 500 whp V6
I've seen gains in the 100+ whp range in a turbo car.
90 TSi AWD Auto - 10.359@128.41
Best MPH: 132.21
Best 60' 1.490
I've looked into it....yes $500 for the Dsteck setup and $150 for new fuel pump....and $800-1000 for injectors and probably $300-400 for fuel pump install as I've heard it's a huge pita to change then you got it.
I've already got ID1000 injectors so no worry there for me but I'd still need the fuel pump...install and the flex fuel setup and then a re-tune. If there were more E85 stations around and the fuel seemed more stable I'd probably go for it as I'm all about picking up extra power.
Best MPH: 132.21
Best 60' 1.490
Yeah, e85 is mostly about running more boost. You pick up power in a bunch of different ways (as Jeff pointed out), but primarily boost is the key.
My setup is approximately a 100hp pickup on e85. I just think of it this way:
A lot of guys run octane boosters, or find 110 or whatever, this is the same thing for my car. Except my race gas is $2 a gallon lol. If there weren't 3 e85 stations within 15-20 minutes of my house, I'd just order a barrel and run it when at the track rather than all of the time.
They are placed perfect around the city for me.
One by my house, one on way to work, one on way out east and one up north.
Debating on taking the car to work today.
Sure is chilly.
BTW,
Walmart has Lucas Ethanol Treatment on the cheap.
Basically $2 a fill up to add.
Grabbing a case of it after work tomorrow.
http://lucasoil.com/products/fuel-tr...th-stabilizers
Hmmmm...
Case of the 12oz bottles is only $76 a case on Amazon.
I think it's a 12 case of 16oz. that you are looking at.
That's quite a deal, that works out to 192oz. total for $76
I paid $100 for 126oz. total. Then again, I pretty much bought the 5oz. case, so that I didn't have to measure or anything at the pump. Looks like I'm paying nearly double (my case is $0.76 per oz. while your case is $0.40 per oz.) for convenience...ugh, what's done is done I guess lol.
Im going from 21psi on 93 to hopefully 30psi on e85 (with new heads, bigger turbo), I better pick up more than 50whp or I'm going to put it on craiglist with thedak.
1987 Fiero GT
Precision 6466, L67, 4T80e, MS3Pro
