Results 1 to 20 of 23
Thread: Cheap 15x8 information
    3,316
    Got some weld wheels with 265 DRs on them from Cam. Turns out they only work up to 04's. They won't clear my brakes. I could either buy about 1 1/4" of spacer to make them work or get some wheels that would work natively and just mount the DRs on them.
    Looking on summit it seems there are options that could work that aren't too expensive. Anyone got suggestions?
    robinson
    1,091
    is it hitting the sway bar or calipers? i know have relocated sway bar to gain clearance so just verify
    /twocents
    3,316
    Well I know its the brakes for sure because when we went to snug them down and turn the wheel you could see a minor scrape where the caliper was hitting the wheel and it wouldn't tighten down fully. But I'll check that too when I get back to the storage place. Just happened to be thinking of this now that the track day is looking good.
    Senior Member Dan B.'s Avatar
    Armagh, PA
    4,331
    First mistake was buying anything from Cam........
    Ahh fuque
    1986 Ranger--2WD, 5.0/T5/8.8.
    Member JUICE's Avatar
    Sep 2014
    uniontown pa
    65
    Ill be running 15x10 race stars and 27x11.50 slicks and don't have a problem I just have to relocate the sway bar brackets
    09 mustang gt 67mm turbo 455whp 496tq on 9lbs
    Senior Member Seer's Avatar
    Apr 2011
    800
    For a 15x8 to work, you'll need a -5.25" backspacing and roughly 25 offset. You only need to relocate the Swaybar on wheels that are 15x9 and wider.
    2022 BMW X4M Competition
    2019 McLaren 720S
    3,316
    but he always has so much for sale!
    Quote Originally Posted by Seer View Post
    cool... that helps... thanks for the info!
    3,316
    well after a quick search it seems I'm not getting away with less than about $175 a wheel, so 1.25" spacers it is and look dumb for the afternoon but at least I'll hook.
    ...won't you need longer wheel studs with spacers that big??
    Apr 2011
    800
    Or you could just buy wheels that fit. These are $188 but will fit without issue.
    http://www.teambeefcakeracing.com/92-580150dp----.html
    2019 McLaren 720S
    at least I'll hook.
    NOT a combination that I would like to see tested .....
    I have to admit...I think that spacers are a bad idea, especially on a car you plan on pushing hard at the drag strip or on a road course.
    3,316
    The spacers I was looking at have studs in them.
    However, based on the feedback looks like I'm plunking down another 400 for wheels, give or take :(
    Armagh, PA
    4,331
    So.........will you be selling the wheels you got from Cam? Depending on what they are..........I may be interested.
    Ahh fuque
    The BOSS GOT SVT's Avatar
    Cranberry Twp PA
    3,044
    http://www.steelcitymusclecars.com/f...one-wants-them
    get these and some 18 in drag radials
    Current Stable
    1993 Red Cobra
    Previous Stable
    2012 White Mustang-Traded
    2003 Black Cobra-Traded
    1998 Black Cobra-Traded
    1991 White 5.0 Conv-Sold
    3,316
    Quote Originally Posted by GOT SVT View Post
    Not a bad idea, but my DR's still have plenty of life in them, and I have the AMR GT500 replicas in 19's already :) Its either get these cheap but pay for DR's or buy 15's and keep my DRs. I think financially I'll take less of a hit with 15" wheels and keep the DRs.
    Dan - They're weld prostars 5 lug pattern. They bolted up to Cam's 04 Mach1 no issues. They are in remote storage so I'll have to make arrangements to get pics.
    Cranberry Twp PA
    3,044
    cool
    I am looking at 19 inch drag radials now too, for the rental and fld's
    probably going with the nitto nt05r 305/35/19
    Current Stable
    1993 Red Cobra
    Previous Stable
    3,316
    can you do 305's on a 10" wheel? My 275's fill the width of a 10" wheel nicely... no sidewall bulge. I'd imagine for 305's its a 10.5" or 11" width, no?
    Cranberry Twp PA
    3,044
    I am putting on a 19 x 10 wheel
    from my experience nitto's tend to run small
    Current Stable
    1993 Red Cobra
    Previous Stable
    Apr 2011
    800
    305 is typically 10.5, but nittos typically do run narrow. I run a 305/35/20 NT555R as my daily street tire on a 20x11 wheel.
    2019 McLaren 720S
