Taken from another forum
2022 BMW X4M Competition
2019 McLaren 720S
With all these changes I wonder how much Ford Engineers left on the table. With the new heads and tubular manifolds my guess is not too much.
You know how some dyno graphs have a torque drop off in the very high part of the RPM band? Because of the way HP is calculated even though there is a drop off, the RPMs above 5250 are high enough that you hit a great HP number. With a "low" peak torque number it tells me there isn't a huge dropoff. That's the kind of powerband I like where you feel the strong torque to redline.
EDIT - that's why even though the torque number is "low" it tells me you have a powerband I would like... nice and "linear"
You turned it up?! yesss... MOAR TORQUE! :) :) :)
absolutely incredible! Tempting not to turbo my car and get a 15 or 16
Those must be some amazing cast pistons in the '15 to survive with that much power.
The rods were the weak part of the coyote. The piston never was. Now they made the rod stronger. The piston isn't really an issue unless you plan on detonating a lot.
2019 McLaren 720S
The number 8 issue was tuning mishaps. Kind of odd now that coyote tuning has been figured out you don't see the number 8 issue anymore.
2019 McLaren 720S
I figured out coyote tuning before they even came out:
Don't turn off the knock senseor.
