Page 10 of 18 FirstFirst ... 89101112 ... LastLast
Results 181 to 200 of 358
Thread: Slowsix's project 3pointh8
  1. #181
    25 in the 1/4 SlowSix's Avatar
    Nov 2010
    Greensburg
    1,309
    Well, paid a deposit on the new motor this week.
    Should be done in a couple months.
    Decided on some parts to go with the motor
    On the hunt for a kb or preferably jmax powermax fuel pump booster.
    Going to get id850s or fuel injector development 1000cc injectors.
    Sct ba5000 maf since the car has a slot maf already.
    Going to bite the bullet on an SFI flywheel - spec billet steel.
    This flywheel accepts a 10.5" clutch so I will be going with a ram power grip HD 10.5" 26 spline clutch.
    I am thinking I may run out of fuel pump (dw300m 340 lph pump) even with the boost of pump.
    Searching for 550 on pump 93 out of the new motor. Going to try to keep it under 20 psi.
    Aside from the motor, supporting fuel, and new clutch/flywheel, the rest of the car is going to essentially stay the same.
    Just a little 500 whp V6
  2. #182
    Keep plugging away. These things take forever unless you are Bob or Sutyak.
  3. #183
    it's soo-tack sutyak's Avatar
    Fairmont, WV
    2,467
    All good stuff. Why no ID1000's? Cost? Call up a local shop and ask for a discount.
    mark
  4. #184
    Nov 2010
    Greensburg
    1,309
    I really don't think it should take too long. Basically all I have to do is pull the front part of the turbo kit off, pull the motor, and then drop the new one in and reassemble.
    Quote Originally Posted by sutyak View Post
    Cost, yeah. I really shouldn't need a 1000cc injector, but Tim said the Siemens deka 80# injectors are a pain to tune. The 60s I'm afraid I might run out of fuel. A set of 8 id1000s is about $1100.
    a dealer on a fb group said they no longer make id850s which I though was weird.
  5. #185
    Fairmont, WV
    2,467
    Call a dealer. You can get just 6.
    mark
  6. #186
    Nov 2010
    Greensburg
    1,309
    I talked to a guy on FB actually. $730 for 6 id 1050x
  7. #187
    Quote Originally Posted by SlowSix View Post
    Be thankful you don't have a diesel and put injectors in it. North of $4000.
  8. #188
    Nov 2010
    Greensburg
    1,309
    Just ordered a clutch, some more exhaust wrap (going to get rid of the terrible fiberglass stuff that is on my crossover pipe), and some DUI 10mm livewires.
    Aside from the motor, the list is now down to
    -spec billet steel flywheel (sfi rated)
    -injectors
    - boost a pump
    - maf
    I don't believe anyone makes a blow proof bell for a v6
  9. #189
    Nov 2010
    Greensburg
    1,309
    I cant even afford a diesel in the first place. New diesel truck prices are crazy.
  10. #190
    I really like my injectors from FID. Stinger has good prices and the dead times provided made them plug and play for me.
    im running 1300's on mine and even in batch fire they idle better than I thought possible (and only 75% DC under load)
  11. #191
    Nov 2010
    Greensburg
    1,309
    Good to know, thanks for the input Bob.
    The ID stuff is priced crazy. If I can get 6 fid 1000 for like $500 I'd be very happy with that.
  12. #192
    The guy at FID worked at ID
  13. #193
    ID1000/FID1050 need Holley 750DP.
  14. #194
    Nov 2010
    Greensburg
    1,309
    carbureted v6, I would be doing it ALL wrong.
  15. #195
    Nov 2010
    Greensburg
    1,309
    Parts starting to come in. Haven't heard much about my motor as of late.
    Ram power grip HD clutch, some new exhaust wrap, and DUI livewires 10mm plug wires.
    Ordered a spec billet steel flywheel as well but it hasn't shipped yet.
  16. #196
    Make sure you wear good rubber/latex gloves when you do the wrap. That stuff leaves your finger nails black for a while till it wears off.
  17. #197
    Nov 2010
    Greensburg
    1,309
    This is the lava wrap stuff. I never noticed it making my hands my black before.
    I have the old school fiberglass stuff on my crossover pipe right now and it is terrible.
  18. #198
    I have never used that before. How does it hold up?
    I always got the DEI stuff. The black always bleeds when you wet it. Drives you nuts! Haha
  19. #199
    Nov 2010
    Greensburg
    1,309
    I like it.
    It doesn't make you itch. You also don't have to wet it. At least I didn't
  20. #200
    I like it.
    When it comes time for me to change my headers...which will be soon...I may give that stuff a go. I am going to swap my hooker super comps with the schoenfeld on mine.
