Page 15 of 18 FirstFirst ... 51314151617 ... LastLast
Results 281 to 300 of 358
Thread: Slowsix's project 3pointh8
  1. #281
    Senior Member blackfive-o's Avatar
    Leetsdale
    421
    Take turbo off and check that the gasket is not blocking the flow?
    "Old Man"
  2. #282
    Will it run “well” without the turbo hooked up?
  3. #283
    25 in the 1/4 SlowSix's Avatar
    Nov 2010
    Greensburg
    1,309
    Quote Originally Posted by blackfive-o View Post
    Gasket is fine.
    I don't have any way to run it n/a unless I run open forward facing headers lol
    Just a little 500 whp V6
  4. #284
    Quote Originally Posted by SlowSix View Post
    So what’s the problem?
  5. #285
    Nov 2010
    Greensburg
    1,309
    Nothing like some flames pointed directly at my radiator. What could go wrong ! Lol
  6. #286
    Nothing a turn down can't solve.
  7. #287
    Nov 2010
    Greensburg
    1,309
    Well, after doing all kinds of diagnostic work.
    Car is getting shipped back to the engine builder...
    Verified wastegate, cold side piping, blow off valve. Re did cam synchronizer timing.
    Even tried another turbo.
    Compression test reads 120 on all cylinders, which engine builder agrees seems low.
    Pretty bummed out. Hopefully this will get taken care of and I'll actually be able to drive the car before summer is over.
  8. #288
    it's soo-tack sutyak's Avatar
    Fairmont, WV
    2,467
    Hate to hear that. I was hoping it was something simple. Let us know what he finds.
    mark
  9. #289
    Nov 2010
    Greensburg
    1,309
    Quote Originally Posted by sutyak View Post
    I was hoping so too, and everyone kept telling me it was something stupid.
    Compression test shows 120 ish on all 6 cylinders. Which being even is good, but low. Should be seeing 150-160 on a brand new motor, plus the fact that it won't spool my turbo.
    Engine builder thinks it may be an issue with my cam.
  10. #290
    Nov 2010
    Greensburg
    1,309
    Well. Update. Car has been at engine builder's shop for about it a week.
    So far - a couple loose grounds.
    And this -
    Not sure how the hell that happened.
    Welded the intercooler up and it makes boost now.
    Attempting to tune it now, but he said the fuel pressure is being weird. Spikes to like 60 psi and holds it there.
  11. #291
    Fairmont, WV
    2,467
    Well, that's certainly unexpected. Glad you got that figured out!
    mark
  12. #292
    doesn't explain low compression test numbers though
  13. #293
    Nov 2010
    Greensburg
    1,309
    Agreed.
    We are having some other issues as well, but so far the car made 427 spinning on the Dyno at 13.5 lbs.
    He is really busy and says he is not sure if he has time to fix a few things that should probably be fixed
  14. #294
    Nov 2010
    Greensburg
    1,309
    Well, another update.
    Intercooler blew another weld apart so we are officially scrapping it.
    Ordered a treadstone 1235 intercooler that is 3.5" core. Almost ordered the 1245 that is 4.5" but probably overkill, and it is on backorder.
    Also changing to a tial Q 50 mm blow off valve to replace my turbo XS RFL that is maybe only 30 mm.
    Turbo is going to be pulled to see if the drain needs re routed or the seals are bad (again). He said the turbo smokes like crazy and is leaking.
  15. #295
    Good times. Hang in there - this happens to all of us...except on Overhaulin’.
  16. #296
    Nov 2010
    Greensburg
    1,309
    Intercooler I ordered is on back order as well. Son of a...
  17. #297
    Need more NA cubes. BBF swap
  18. #298
    yelled from the sidelines .... /stickpoke:
  19. #299
    Nov 2010
    Greensburg
    1,309
    In the words of Bob "needs more RPM"
    btw, bob do you have a treadstone on your car ? How is it and what size ?
  20. #300
    Yes mine is Tredstone, best of the economic intercooler in my mind ....
    cant remember part number and I think they changed their system anyway ... it’s a basic 3” core, 12” high, 28” core length, 3” in and out
