Results 1 to 10 of 10
Thread: Drag Race Tires
    Jan 2011
    Allison Park, Pa.
    367
    Drag Race Tires
    Weld racing wheels recommend that to spin balance the wheels properly, you should use a lug centric adapter plate, not a centering cone. Does anyone know of a shop in the Pitts. area who might have one. Thanks Vince
    2,483
    Never seen one or heard of one.
    Jan 2011
    Allison Park, Pa.
    367
    What the adapter allows you to do is, center your rim by using the lug nuts instead of using the centering cone in the center hole of the rim. The idea being, a better high speed balance. Vince
    Your mom cwh19's Avatar
    May 2009
    Greensburg
    1,383
    Sears has lug balancing, at least the Greensburg one does. You have to tell them thats what you want though because the cone is their default.
    15gt
    94gt
    Assuming you are talking about ProStar / Draglite / RodLite type wheels, I've just never got them to balance right with anything. Add in that sooner or later the tire is going to move on the wheel if it's not screwed, I just stopped trying. Never could tell a difference. I've just stopped trying
    Jan 2011
    Allison Park, Pa.
    367
    I should have included that they are Draglite wheels. I've never had a problem with my current tires with a regular balance. Since I was changing the front tires,I just wanted the best balance possible.Bob, thanks for your info. If I don't find a close shop with lug balance, I'll do a regular balance.
    2,145
    So Weld is saying that there wheels are not 100% true from the center hole to the lug nut holes? How does this work since all the cars I have worked on center the wheel by the center hole?
    9 times out of 10 you going to spin the tires on the rims a bit anyhow. Just mark the and see Unless they arebead locks.
    Stock 03 Cobra Vroom Vroom!!
    The issue is with the construction of the wheels. You basically have two thin sheets with a free floating hub in between them. When you bolt them on the car with the proper shank lug nuts, the hub centers up properly, and the two sides of the wheel compress on to the hub. You can look at the spokes of my ProStars and see the gap in the middle until the wheel is properly tightened.
    If you try to balance them using the center hole and a cone, the hub could be not centered (and actually floating around) and they wont balance properly.
    The Weld wheels (of the type being discussed) center on the shanks of the lug nuts, not the center bore.
    South Hills, PA
    4,052
    I've never balanced the rear wheels on my strip cars.
    I have three sets of rears (slicks, DOT's, and DR's) and my fronts, and not a wheel has a single weight on them. I drive mine all the time, and although not ludicrous speed, trap over 125 mph ... no issues.
