Page 1 of 4 123 ... LastLast
Results 1 to 20 of 68
Thread: Four Eye Foxbody Guys 1979-1986 Mustangs
    Curious how many 1979-1986 four eye foxbody guys are on here. Post a picture of your ride so we can see who has what on here.
    I'll start.
    1986 Mustang GT purchased from Warren Wooten Ford in Cocoa Florida.
    Modifications:
    Stock 302 with 1.6 Roller Rocker Arms and a ported/polished 1993 Upper intake. BBK 65 MM spacer and Throttle body
    Dynomax 2 1/2" exhaust with BBK catted H Pipe
    Ford Stainless Steel 1 5/8" shorty headers
    March Underdrive Pullies
    Kenne Bell Ram Air
    Ken Brown subframes, Gload brace and strut tower brace
    Five Lug four wheel disc conversion with Cobra Red calipers, stainless steel brake lines, cross drilled/ slotted Rotors, Moser 31 spline axles with a Ford Explorer 31 spline Carrier, Ford Motor Sport rear girdle, Steeda Weightjacker lower control arms, 94 Mustang Spindles with 1993 Mustang V-8 K member (wider than the 79-86 V-8 K Member)
    Bulitt Mustang coil Springs with Koni struts (front) and Air shocks on the back
    17"x9" Cobra R wheels with Nitto NT555 tires.
    Hurst Shifter
    Ford Motorsport Aluminum Drive Shaft
    Cervini 1 1/2" Mach One hood
    Not the fastest but its a nice clean 29 year old cruiser with the original paint (except the hood)
    Future plans:
    I have a warmed up 302 shortblock with a good strong cam (Thanks Ron) and GT40 Yates Aluminum Heads (Thanks Vince). Going with a GT40 Tubular intake, 1.6 Roller Rockers. Thinking of removing the Catted H pipe and going with long tube headers. I would love a T56 in her but that may be years away. I have a Cervini 2 1/2 Cowl hood. Frustrated it hits my strut tower brace. Looking at a HO Trends Fiberglass hood.
    Like I said she is just a cruiser. Never will be the fastest but I dig driving it.
    I have an 81 that ive had since I was 15 years old. Its been through a couple transformations. I built it in 1997 the first time. Im sure many of you guys have seen it. It was in the readers rides in MMFF december 2001. then I painted it silver, then red. It has had a 289ci motor that went 13.79 i built myself when I was 17 years old, then in 2001 i built a 460 that would go 10.50s and 9s on spray, then i built a 501 that would go 9.80s on pump gas. Then I added a couple 74mm turbos from a semi truck and it went 8.50s@169. I still have it and love it.
    RRT juice_man_86's Avatar
    Uniontown, PA
    533
    I have a maroon 86 Mustang GT. this is my second 86 Mustang. Both had nitrous, but this one is faster. I started with the motor that was in it when I purchased it. It was a 40 over rebuild with crap Pistons. A little nitrous and too much rpms later and a ring seized in a piston. I then began my build which took six long years to "complete". It now has a 327 stroker in a Ford racing Boss block with procomp aluminum heads and a custom grind nitrous cam from Bullet. It makes 355 To the tires on the motor on Rodeheavers dyno. I'm currently hitting it with a 175 shot, but want to add a little more with a second stage. I'm in that process right now. I try to make it to all the Flashlight Drags and will be at the track rental with it.
    Here it is when I first got it
    And now
    All stock down to the tires
    355hp n/a
    520hp on nitrous
    My BBF powered 82
    Love me some four-eye!
    U.S. Citizen 86GT's Avatar
    Sep 2011
    Monroeville
    323
    Different shots of my 86's
    Black Bess, over 169k miles. I was leaving at 4900 rpm last Friday.
    Rodeheaver's Hot Rod Shop
    15 W. Cross Ave.
    Masontown Pa. 15461
    724-737-5088
    www.RodeheaversHotRod.com
    Sep 2011
    Monroeville
    323
    This one doesn't run
    I've had it for a while too.
    15 W. Cross Ave.
    Masontown Pa. 15461
    724-737-5088
    ^^^^ wasn't that one for sale a few years ago? Nice ride!
    Yellow is faster!
    York PA
    273
    85 coupe, coyote swap with all the good stuff.
    this past weekend at MIR:
    right after paint:
    Jason
    Just a little stock coyote that runs low 10s!
    May 2008
    Hampton
    544
    Four-eyed Fox? Just bought it 20 years ago. Found it in Charlotte, NC before the internet made car shopping easy... I went to Barnes & Noble on Tuesdays when they received the Sunday newspapers fro Atlanta, Charlotte, D.C., etc. Old School! 4-barrel carb and 5-speed stick.
    158,000 miles... mostly original paint! Same engine since we threw a Summit catalog at it in 1998. Edelbrock carb, intake, and aluminum heads. E-cam. Balanced and spins smooth to seven grand. In '98 you could go Corvette hunting with 325hp. Today, it can still trash a '98 Vette!
    '87+ front rotors with Lincoln Mk VII calipers, Turbo Coupe rear with 3.55s and discs too. Subframe connectors, lowered about an inch...Eibachs I think, but it's been awhile!
    i've had it to St. Louis, Virginia Beach, Raleigh, Quaker City, Nelson's Ledges, Beaverun (been a few years), FLD's at Zelie (been a few years!) and it's the car I drove the night we got engaged 16 years ago.
    Occasionally cold A/C.
    Fairly crude, borderline obnoxious, always fun, and dead reliable.
    What's great about Greg's car is that it gets used and enjoyed as much as any 30 year old car out there.
    My '66 was in the middle of its long initial resto-mod when I was invited to go for a lunch hour test ride in Greg's '85 GT ragtop. At the time all Greg's go-fast goodies were pretty fresh and Greg was more than willing to demonstrate exactly how well they were doing their job! Needless to say, that ride was just what the doctor ordered, as it jump started my enthusiasm for my own build, which had stalled a little bit due to getting married and buying a house. Thanks for the boost Greg! I know you'll keep racking up the miles and smiles in the GT!
    A lot of you know my Capri ... 84 RS Turbo car, relentless on it.
    This thread is full of win.....
    charleroi
    478
    Nice cars fellas!
    Member Red98GT's Avatar
    Sep 2007
    Uniontown, PA
    64
    Nice rides. Lots of four eyed love.
    98 Mustang GT
    P1sc, 4:10's, PI Intake, alum. Dr. Shaft, Eibach Springs, Steeda Tri Ax, Bassani X Pipe, Bassani Cat-Back
    NEWB 83dropboy's Avatar
    West Mifflin, PA
    113
    Bought this back in Nov 1989 - lots of good memories, more to come, had it out Saturday
    1983 GLX convertible, 1992 high mileage roller block, GT-40 irons, B303, 1.7 rollers, torker II, Edelbrock 600(1406), T-5, 3.27 8.8 rear, 100 shot, 380RWHP/430RWTQ = best ETA 12.8 @ 104
    South Hills, PA
    4,052
    Need me some 86 !
    Its nice to see that some guys still have old four eyed fox bodies. Sometimes you feel dated with an older Pony but they will always be special to me!
    Dec 2008
    Natrona Heights PA
    3,056
    NiiiiiCE!!!! We have a NMRA Coyote Stock racer on here!! Some awesome rides in here! If I were to get a Fox body it'd be a '82 the year I was born, also because I wear glasses! lol
    Bu-2000-bash
    ALLSQUAD
    Steel City Muscle Cars
    CarCruises
    Flashlight Drags
    NMRA
    UMTR
    Modded Mustangs
    NHSCC
    Yellow is faster!
    York PA
    273
    Quote Originally Posted by AdamantiumSilvr View Post
    Yeah not from the burgh anymore but recently moved back to pa. My parents still live in Latrobe.
    Jason
    Quote Originally Posted by Donstang86 View Post
    I'll start.
    Modifications:
    Kenne Bell Ram Air
    Hurst Shifter
    Future plans:
    Future hood...coming shortly now that I am back to work!
