Banned
Banned
Banned
finished up the factory style mini tubs, once the truck goes to body shop it will be getting a white spray in liner
Banned
started getting firewall ready for paint work... shaved off everything i wasnt using anymore, relocating the wiring harness and filled up a bunch of holes
Banned
Banned
Banned
Banned
Banned
Banned
Banned
Banned
Banned
had the wheel side of my front fenders bedlined
also had my widened wheel tubs done in bedliner
Banned
Banned
Banned
Banned
heres a pic of my Mast heads being drilled for 1/2 studs
Banned
Banned
Banned
a run down of motor
Mast 295cc 12* cathedral heads
Diamond ls7 pistons
Callies dragon slayer
Oliver billet I beams
ARP 1/2" head studs torqued to 120ftlbs
ATI super damper with aluminum hub
cam 235/243 646/664 114+4
compression is around 9.68:1 i wanted 10.0 but head swap dropped it
Ported Holley Hi-ram 102
LSX block
Lunati Tie bar lifters
ARP mains hardware
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
