Looking good man. Always clean work on your rides.
Really Nice truck and the craftsmanship is top notch!
Sam
Wow, crazy build--nice work!
Any guesstimations on your times or better yet, where do you want to be. That is one beautiful truck !
Very nice. Alot of patience with a clean build such as this, I like the gumband clamp.
Man the truck looks good. Like some people have said, your work is top notch but your attitude drives people away. If you could curb that you would have a hand full of trucks like this sitting in your garage. I am not being a dick, just giving you something to think about and learn from some of the shops you visit.
Stock 03 Cobra Vroom Vroom!!
I meant that you own.
Very impressive work George.
Now that we are having a civil chat, I do have a question about your builds and turbo choice. Do you find that the higher ci of the LS builds requires the twin 76mm turbos? Coming from the modular side of things and less ci it cause hellish turbo lag. I think the biggest I would go on a built mod engine is twin 67s or a single 88mm. Both options would take us to some crazy power figures on the proper fuel.
something you need to consider and its easily over looked, ppl look at compressor size when you need to be looking at turbine size....You can only flow as much as the turbine can flow so the compressor size isnt as important as many think
take these examples, that 2010 camaro i built it has 7665s, thats a 76 compressor paired with a 65mm turbine... the 65mm turbine will never max the compressor out.. This combo flows almost the same as the 6265s i had originally on the car but with the cost of them its why they were used
now when you have a even pair like my 7675 the turbine speed is matched with compressor speed so they max out together
now you have outlaw 76s which some of them have 100mm turbine wheels, these are typically 1/8 mile turbos, they want max boost now and not be choked up by turbine
as for Mod motors, there was a lightning with a similar motor as I have for my lightning that ran similar turbos as my 427...that truck ran 7s
problem is with say the smaller motors like your 4.6 is they just dont have the flow to support a large turbine unless they spin serious RPMS, but for a combo like that you need gearing, compression, huge stall to get off the bottom and use full topend
like the lightning i did with the billet 8284 with having the turbine slightly larger then compressor its a good match for a 5.4
with todays turbos the old way of thinking is basically thrown out the window since the modern turbos make up for such "lag" as some would say.
