[ATTACH][ATTACH][ATTACH]DSCF0016.jpg[/ATTACH][/ATTACH][/ATTACH]Hey all-
Kind of a new member here, joined last year.
I am reluctantly selling my '03 Cobra that I bought last year. I had every intention of doing open track events, but my place of work is going through quite a few changes, and I'm going to find myself working many, many weekends. So the car just sits.
I am the second owner of the car. The original owner did all of the mods you see listed here. He set the car up for open track.
I'll touch on some of the mods, but you can PM or call me because the list is very extensive. There is much more than is listed!
-Ported throttle body, intake, supercharger, by Stiegy.
-4# lower
-Fluidyne rad (dual core)
-Oversize heat exchanger
-468 hp. on the dyno
-Steeda tri-ax shifter
-Dif. drain
-Magnaflow w/ cat. delete
-Brembo front calipers
-Powereslot F. & R. slotted rotors
-Kenny Brown subframe connectors
-KB jacking rail
-KB subframe matrix
-KB front tower strut
-KB rear shock tower brace
-Maximum Motorsports tubular K- member
-MM tubular control arms (off set)
-MM offset steering rack kit
-MM bumpsteer kit
-MM front coilover conversion
-Bilstein shocks F.& R.
-Hypercoil springs F.& R.
-MM sway bar relocation kit
-MM caster camber plates
-IRS carrier urethane bushings
-IRS carrier subframe brackets
-MM coilover conversion
-Sparco seats and 6 point belts
-Roll welded, removable harness bar, ( DOM steel)
-Extra set of Konig Villains
Things I had done to the car-
-Rad. and heat exchanger flushed
- Replaced timing chain tensioners, guides, timing chains.
All work done by one of the best certified SVT Techs in the area. ( Thanks M.!) Just the sweet sound of the injectors!
-Replaced the TPS
On a scale of 1 to 10 for body and paint, ( with u1arunit's paint being a 12!!) I would say this car is probably 8.8 to a stong 9.
32,000 miles on the car.
Nothing needs done.
No engine tick.
Handles great on the road. I can only imagine what the car would do on the track!
Asking $26,900
Feel free to call me or PM.
Ted
412-716-8943
