Page 2 of 3 FirstFirst 123 LastLast
Results 21 to 40 of 42
Thread: Clutch problem---2000 GT
  1. #21
    Member Mark Aubele's Avatar
    Trafford, Pa
    2,308
    What's wrong? :)
    2014 M235i (wife's)
    1964 Ford F-100
  2. #22
    Senior Member Dan B.'s Avatar
    Armagh, PA
    4,331
    Nothing JB weld can't fix.
    Ahh fuque
    1986 Ranger--2WD, 5.0/T5/8.8.
  3. #23
    likes turbos Tom's Avatar
    Rostraver
    918
    should have stuck with an auto
    1987 Fiero GT
    Precision 6466, L67, 4T80e, MS3Pro
  4. #24
    3,316
    I've seen worse...
  5. #25
    Armagh, PA
    4,331
    A least it was the pp side that grenaded.
    Ahh fuque
  6. #26
    Senior Member blackfive-o's Avatar
    Leetsdale
    421
    Wow!
    "Old Man"
  7. #27
    Fat guy in a turbo car JeffreyCole's Avatar
    Feb 2015
    904
    Quote Originally Posted by Dan B. View Post
    That'll buff right out.
    90 TSi AWD Auto - 10.359@128.41
    Best MPH: 132.21
    Best 60' 1.490
  8. #28
    Yellow is faster!
    York PA
    273
    Damn that is serious stuff! I have a 11" pressure plate down here. I have a 11" disc as well but it's 26 spline. Let me know what it's worth to ya, I can ship it out. It has less than 2k miles.
    Jason
    Just a little stock coyote that runs low 10s!
  9. #29
    Armagh, PA
    4,331
    Summit order should arrive today. But thanks for the offer.
    Ahh fuque
  10. #30
    Rostraver
    918
    whens the powerglide going in?
    1987 Fiero GT
  11. #31
    Armagh, PA
    4,331
    Almost two weeks on the new clutch. Everything is driving perfect.
    This was the most painful clutch swap I'd ever done. The long tube headers made it tough. If I ever have to remove the trans again, I will be dropping the k-member or (more likely) selling the LT's and installing shorties......or forward pointing ones that spin one of those terbou things that all the kewl kidz talk about. Would also be easier if the trans came off the bellhousing from the outside like a T5. That would have made it doable with the headers in place.
    Anyhooo......pedal engagement is dead one, cable adjustment is perfect and she shifts like butta!! Cindy is happy........which makes everyone happy.
    Ahh fuque
  12. #32
    Congrats Dan-O!
  13. #33
    Member 2000GT's Avatar
    Plum, PA
    1,611
    Did you have to remove the LTs when you took the transmission out?
    Sent from my SAMSUNG-SM-G800A using Tapatalk
  14. #34
    Yes he did - he had lots of fun!
  15. #35
    Armagh, PA
    4,331
    Driver side-no. Loosened motor mount.
    Pass side-yes. Took out motor mount. Jacked up motor in that side. Took out all header bolts. Just that sucked. Trans did come out with the header still in (but totally loose) but it was hard. To get back in I had to install the trans and header at the same time. That was a major pita. My 387w ranger is easier to work on.
    It it will for sure get shorties if it ever needs to come out again.
    Ahh fuque
  16. #36
    Plum, PA
    1,611
    I don't envy you at all!
  17. #37
    stock k-member or aftermarket?
    If stock....wow...should've dropped it....doesn't take that long.
    Keep the L/T's, just drop the K next time.
  18. #38
    Armagh, PA
    4,331
    Stock K. Drop it but suspend motor from a brace?
    Ahh fuque
  19. #39
    indeed.
    STOCK K header bolt removal with K in place makes u an SN95 clutch removal ROOKIE...............
  20. #40
    Oh snap!!!
