$650 for the full set of wheels, tire pressure sensors, and tires. Details below:
OEM Ford F150 FX4 / STX Appearance Package Wheels
- 18 x 7.5
- 6 x 135 bolt pattern (Will fit 2004 thru 2014 F-150)
- +44 offset
- Machined face with metallic gray insets
- Very good condition, no curb marks, only light scratches from getting tires mounted
- OEM Ford valve stem TPMS still installed in all four
Falken Wildpeak All-Terrain AT01 Tires
- LT 275/70R18 (~1 inch taller than factory size, but will still fit stock or leveled suspensions)
- Load Range E "10 ply" weight rating, huge improvement in handling and towing behavior
- Worn, but a little life left. 3 tires measure at least 5/32" of tread remaining and 1 measures at least 4/32". I rotated them every 5-6k miles so they are all relatively evenly worn for all terrain tires, no cupping
Only selling because I upgraded to aftermarket wheels.
