2000 gt with T45.
New cable in, new quad in, new PP and clutch also in. And a new TOB. Before installing I turned the input shaft and shifted the trans. It fully engaged all the gears cleanly.
Cable nut is adjusted a couple turns beyond touching the fork.
Set it on the ground, fired her up and backed out of the garage. Went into gear smooth. Went to shift into first and it was grinding. But it slid smooth into 2nd. Since it's got 4.10's I could easily pull out in 2nd. Start down road and it wouldn't go into 3rd but slid into 4th. So basically it goes into the "down gears" but won't go into the "up" gears.
Snugged the cable a bit more but still no 1-3-5. Took shifter apart and it seemed fine. Did not pull the base off of the case though. I was tired and done for the night.
Ideas please.
