306 tfi heads rpm 2 intake built c4 etc
Mustang parts for sale
306 short block -- 1000.00
Arp rod bolts
Forged Pistons
Moroso 7qt pan
Fms lifters
F cam
Cloyes adj timing set
Arp oil shaft
Melling hv pump
Timing cover
Standard rot wp
Balancer
This a complete fresh short block
Trick flow twisted wedge track heat heads -- 800.00
Good dbl valve springs
Scorpion 1.6 3/8 rockers -- 125.00
Stud mount
Edelbrock performer rpm 2 -- 475.00
Bbk 75mm Tb -- 125.00
Egr delete spacer included
Bbk cold air -- 50.00
Adj Fuel press reg -- 50.00
Stock rail mounted
91 efi harness -- 150.00
Efi sensors included
O2 harness included
Perfect for efi swap
A9l ecu -- 100.00
Bbk 1 3/4 long tubes 302 -- 175.00
2.5 exhaust -- 175.00
Complete exhaust
Off road h pipe
Dynomax bullets
All one piece
Un bolts at headers
WONT SHIP THIS
Weld draglites -- 600.00
4 lug
15x8 5.5 bs
15 x 3 1/2
275/60/15 et pros 1/4 tread
165r15 fronts NEW
C4 tranny setup -- 1900.00
Cf clutches
Coleen steels
Roller iced
6 gear planet
Billet servo
Hardened shaft
Pro trams brake
Deep alum pan
Sfi alum bell 157th
Lockable dipstick
Ptc custom converter 3800
Sfi block plate
Pro thane trams mount
B&m ratchet shifter w/ cable
Sfi 28oz or 50oz flex plate
This is a badass tranny setup
Built with the best parts
Originally a pa supercomp
Was gone through and modded even further
Ready to install and go
Aeromotive 340 in tank pump -- 75.00
Aluminum radiator -- 150.00
Solider roller cam -- 125.00
347 cid 7000 rpm shift
Msd blaster coil -- 25.00
Fms 9mm wires -- 50.00
Black color
Hardened moly pushrods -- 50.00
7.500
PLEASE text 814-207-3299
Located in Altoona pa 16601
Only trades would be for weld pro star big and littles
750-950 carb
Carb style nitrous kit
Sumped tank
A1000 or carb fuel system
Car is not for sale , DONT Ask thanks
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
