Results 1 to 12 of 12
Thread: 2006 Pontiac GTO
    Mars, PA
    1,696
    2006 Pontiac GTO
    The time has come to part ways with the Gto. The car currently has just under 67k miles. For the racers out there it will consistently run in the 11.4x range at around 120 mph with a good tire. I am asking $16,000 but will entertain reasonable offers. The modifications are as follows.
    Engine
    Milled Ls3 heads
    Ported Ls3 intake
    Svede cold air intake
    Slot style maf with 100mm housing
    Custom comp cam with supporting valvetrain mods
    Ls3 injectors
    Deatchwerks dw65c fuel pump
    Exhaust
    1 7/8 Kooks headers with catless midpipes
    Magnaflow magnapack mufflers
    DMH electric cutouts
    Drivetrain
    Rossler 4L65e transmission
    FTI 3800 converter
    Motive 3.90 gears
    Truetrac
    Suspension
    Pedders front 3/8 drop springs
    Pedders gsr struts
    Koni adjustable rear shocks
    Stock rear springs with drag bags
    There are two issues with the car that I am aware of
    The trans will intermittently set p1810 and p1815 codes. Once the codes are cleared the trans operates as it should. I have replaced the part associated with the code so it may be a wiring issue. I have not had the time to have it looked at.
    The drivers side knock sensor needs repaired/replaced
    Dennis
    2006 GTO
    Gone but not forgotten
    2015 SHO
    Mostly stock
    2014 Cruze
    Living the MPG life
    If You Wanna thedak's Avatar
    Jul 2008
    DMB
    Nice
    Sharp goat. What's next....C6Z?
    Mars, PA
    1,696
    Maybe a house. I'm going to take a break from cars for a bit
    Dennis
    2006 GTO
    2015 SHO
    Mostly stock
    2014 Cruze
    Living the MPG life
    Fuwkawee
    5,151
    This is a nice Goat. It sounds insane with the headers uncapped. Good luck Dennis.
    17 Ram 1500 Big Horn Hemi
    16 Comp O GT Performance Pack
    Nov 2010
    Greensburg
    1,309
    Good luck with selling it Dennis. I actually never realized that was an Auto car. Car sounds nasty.
    Just a little 500 whp V6
    Brookline
    2,897
    House, pfft. They make FHA mortgages so you can keep your muscle cars too! GLWS.
    Mars, PA
    1,696
    Thanks guys
    Dennis
    2006 GTO
    2015 SHO
    Mostly stock
    2014 Cruze
    Living the MPG life
    Mars, PA
    1,696
    Spring time bump. Price drop to 15k
    Dennis
    2006 GTO
    2015 SHO
    Mostly stock
    2014 Cruze
    Living the MPG life
    Quote Originally Posted by Slow01GT View Post
    Don't sell it!
    Mars, PA
    1,696
    Still here. Open to offers on this thing
    Dennis
    2006 GTO
    2015 SHO
    Mostly stock
    2014 Cruze
    Living the MPG life
    South Hills, PA
    4,052
    Have a person interested not on this forum. Can u post your # or text me so i can give it to them . 412 651 1920
