I plan on dropping the Ranger a couple inches all the way around this winter. I have a S-10 rear leaf set up on the truck to take advantage of the mounting points....they are under the frame vs outside the frame like a typical Ford. I can tuck a much wider wheel without bed side and leaf spring clearance issues. This also allows me to use any S-10 rear suspension components. My main issue is not how to lower it, but the safety of it. The truck currently sets on 1.25" homemade lowering blocks. With the bottom leaf plate/shock mount and traction bar bolted together they set slightly lower than the bottom of the wheel. My concern is that should I ever get flat, the truck will be riding on the traction bar instead of the rim. If I go lower (I'd like another 2.5") the problem would be worse. Is this an issue? Or do the "lowering block" guys do this all the time?
I can make another set of blocks so the cost of virtually nothing and two hours of time. The expensive way is to go four link and coil overs. This would run around $1,400....not in the Ranger budget....and take much longer. I also like that the current set up is simple and just plain works.
Below is a pic of the current components.
