Results 1 to 18 of 18
Thread: spec 2 clutch issues
    Big member venom's Avatar
    North Fayette Township, PA
    1,344
    the thing is very touchy. about half the time when pulling out from a stop it looks like its my first time driving a stick. seems like there is no slipping at all, either in or out. this normal?
    My Ram Powergrip clutch is pretty touchy also, but im starting to get use to it.
    Your experience with your spec clutch is EXACTLY why I do not like them. I almost bought a spec clutch when I replaced mine a few years back until I drove a car with one... I knew within the first 10 seconds of driving it that I wouldn't buy one due to its on/off nature. I wanted a clutch that could hold everything I could throw at it, yet still be docile enough to be street driven. I found that in my pro motion "kustom" clutch setup. I'm not sure about the stage 2 spec, but I know the stage 3 and up lack a monsels (sp) spring between the clutch material and the disc itself which makes the situation even worse.
    3,356
    It is a marcel spring Paul. :)
    Mark
    LeMans Blue Z06
    Power Adder
    236
    In my Beretta GTZ I have a spec stage 2 and it works great. I can ride the clutch on a hill and it won't chatter at all. Do you have a clutch quad and a firewall adjuster?? I also have a stage 3 in my 00GT and it can still be feathered, but it does catter a little bit. The only Spec that I drove that was like an off on switch was a stage 5.
    Chris Kauffman
    1988 408LX drag car
    ask mikeymustang about the spec's
    he likes to weld them to the flywheel for fun
    1969 Camaro restomod/project
    1967 camaro
    2011 mustang procharged
    93 reef blue notch blk/int
    92 calypso notch blk/int
    86 t-type
    1972 chevelle project
    I just adjusted my Ram Powergrip today and made it alot more street friendly. I set it so that it picks up almost immediately off of the floor, and now im really starting to like this clutch alot more. Very close to my stock 100,000+ mile clutch except for the fact that it dosent slip.
    Wrench Wench & GeekGrrl stanggrrl's Avatar
    Monroeville
    321
    Quote Originally Posted by went12s View Post
    Adam - you're hysterical. But you're right, he did weld 2 of the suckers and we have images on the web page.
    Alicia*
    www.mikeymustang.com
    I had a stage 2 in my notch. It wasnt too bad but I like my centerforce better.
    1,344
    Quote Originally Posted by Chris00GT View Post
    thanks guys...i do have the quad and firewall adjuster. i was thinking since i posted this, and maybe i should check the adjustment. maybe the clutch wore in a little bit, and it needs some fixin.
    For optimum transmission life & performance, 0.70" airgap is reccomended.
    Thats right where I set mine.
    i personaly hate the spec clutches, i have great luck with centerforce, they feel great for daily driving and grip like a mofo at the track
    North Hills
    1,229
    im not a fan of my spec stage 2 at all. dump it or nothing is all it's worth IMO
    boats n hoes fork5o's Avatar
    Hopewell
    833
    how do you know how far its set at?
    i just changed my clutch so i guess it would be good to get it set right
    -Joe
    1995 5.0
    The Car
    Member mlowry1260's Avatar
    Caledonia, Ontario
    620
    I think that's the nature of kevlar clutches.
    Mark Lowry
    I like hair dryers Twin01cobra's Avatar
    Wherever I want
    1,270
    I have a spec stage 3 in my car and it's tricky getting used to, can't slip it like the stocker, also chatters a little unless you get the revs up then it's no problem. Can't speak for the other clutches cause I never tried them.
    General Douglas McArthur
    1,037
    I have a ram power grip HD on a steel flywheel and it is very streetable.
    2016 Mustang GT
    Spec2 clutch on a Fidenza aluminum flywheel. I daily drive it and find it feels perfectly normal with excellent street manners. I don't have any chattering and can pull out on a steep hill without an issue. I used this same clutch on a different car before and liked it alot.
    6grand dump and go at track
  1. Spec 2 Clutch
    By 2000GT in forum Ford Vehicles
    Last Post: 09-01-2014, 10:04 PM
  2. FS: Spec Stage 2 clutch. Almost new!
    Last Post: 07-24-2011, 08:23 PM
  3. Spec Clutch
    Last Post: 05-13-2011, 07:58 AM
  4. Clutch Issues
    Last Post: 01-20-2009, 07:12 PM
  5. spec clutch for 2.3 4 cylinder
    By fast4ord in forum Ford Vehicles
    Last Post: 02-22-2008, 11:02 AM
