Recently I parted ways with my 400hp turbo Ford Focus and picked up a turbo 2004 Mach 1. It has been through a couple owners, and each before used and abused it accordingly. Now I'll be undoing the past 11 years in hopes of getting it up to my standards.
Here are the overall details according to the seller. So far everything checks out.
87000 miles on the body and about 2000 on the built motor.
Motor specs:
8.5:1 compression (I verified cylinder compression before buying)
Manley rods
CP pistons
ARP head studs, rod bolts, cam bolts
MMR oil pan
Teksid block out of an 01 cobra
Stock heads and cams
Turbo kit:
Hellion single 76mm kit with custom cold side
BA5000 MAF sensor
Precision PTE 7675 turbo
Full 3in exhaust to dump before axle
Trans:
T-3650
Spec stage 3+ clutch
MGW short throw
Rear end:
Fully built 8.8 with 31 spline moser shafts
Factory 3.55 gears
New clutch packs
Suspension:
UPR Tubular k member up front with fully adjustable coil overs
Caster camber plates
Fully adjustable coil overs on the rear
Rear upper and lower control arms from UPR
Fuel system:
80lb injectors
Lethal performance return style fuel system with dual walboro pumps with adjustable regulator.
Tuned by Rev Auto
Here are my plans now through Spring 2016:
- New seat foam
- Rear tires (315/35-17 Nitto 555R)
- 26" slicks
- Full length UPR subframe connectors
- Weld torque box seams
- Magnaflow exhaust
- Fix turbo oil drain (done)
- Replace pinion seal
- Moser diff cover
- Weld axle tubes
- Paint rear
- Spherical/adjustable Granatelli upper control arms
- Replace worn out steering wheel
- Remove all unused wires and trace existing wires to nowhere
- Rebuild a TR3650. Originally built for 700hp by American Powertrain. Needs a 3/4 syncro I believe. 26 spline
- New clutch. McLeod RST twin disc? 26 spline
- Fidanza flywheel
- Likely change to smaller turbo for broader power band. Borg Warner S366SX-E 66/73 ?
- 2001 Cobra intake cams
- Get the tune file from Rev Auto so I can make future tune adjustments myself
The short-term goal is to have a strong mid/low 10-second car full weight without a dedicated drag suspension that I can reliably drive to the track and make it home without breaking stuff. Currently makes 667whp and 631 lb-ft torque. I want to keep it around that power level but a broader curve (a full 1,000 RPM earlier).
I also don't want to make the car so aggressive that I don't enjoy driving it.
How it looks right now, minus the rear:
Oil-covered rear from leaks:
Cobra steering wheel for the replacement:
