Ppl think im GM but ive owned both and currently own both
Both compaines have good points both have very shitty parts...you gotta take the best of each and look past the bad
I'm curious why you used a BW on this build and Precision on the other?
Hydroboost conversion completed on a 1500
Had to use a 3/4 master that accepted 15mm nuts
Not all gm master cylinders use 15mm some are 13mm, regardless of 1500 or 2500 chassis
Only needed to merge 1 line for this conversion
With the 3/4 master i should now have much better control over my 4 wheel disks
Its possible but i cant be certain...my truck didnt come with my current brakes
I robbed cocaine of its dual piston rear calipers and my brakes always were soft especially from the cam...this now should fix that
Heck I'd be happy seeing Casper let alone Cocaine. Awesome stuff!
Any concern with that front cooler heating up your intercooler?
I dont mess with any water mixture but meth is a great source but may do e85 spray as main
I tried it a few times towing and saw gains and easier to get then me going to mars to fill my 55gallon drum of meth
that is unbelievable. awesome work.
2018 Jeep Grand Cherokee
1931 Ford Model A - Project
1991 BMW 325iX
1978 Ford F150
1952 Ford F2 - Project
and im about to change oil for the first time here in few minutes
Wish you'd stop F'n around and build something already...
