Had a little free time today so built a rear seat delete from luan. Still have to pick up some cheap lightweight carpet to make it fancy-like. Uses factory bolts and mounting points, so no extra holes
with all these mods you'll be getting top dollar when you sell it in a few months...
http://www.steelcitymusclecars.com/f...n-Cam-s-car%29!
Fiero seat would have been more comfy but would burn much better.
Fingers crossed :)
Well theres the empty trunk behind it and the metal floor pan under it, so I think it will be OK
I tried to use a Fiero seat but the parts car burnt to the ground before I could get the seat out. bummer
I did not have the time or patience to make a rear seat delete so I bought one. Looks great! What's next on the list?
-Barry
Lookin good! Maybe you can do my shift bracket when I come down since you're back in the groove with modding mustangs
Cool... the dollar is slowly making a comeback so I'll prolly wait until Im there to buy parts anyway
so finished up the seat delete today. Pretty happy with it, and it's super light :)
Turned out nice!
2015 Charger Hellcat
85 GT
73 F250
Lifted, 35's, 460 4spd
Real name = Ray
Nice job - looks good!
thanks guys, it's not bad for a first attempt. philly thats the front seat belt your seeing in the pic. it didnt have rear belts when i bought it
So new day, new project checked off the momumental to do list for this car, Changed the oil in the procharger today. Its supposed to be done every 6000 miles. No clue when or if it's been done before. Other than the hard to get to drain plug, not a bad job
Been wrenching on the breaky-est mustang ever as always. Changed the plugs which is pretty straight forward on these cars. Removed the inner fenders and finished up changing out the last four worm clamps with t-bolts. Quite happy that is done. Took it out monday night and a horrific screeching noise presented itself that kept rhythm with rpm rise, but was quiet at idle. hand spinning the alternator produced a pretty loud dry bearing screech. Ordered and installed new alternator. Started back up and after about a minute it started a loud chirping noise. Opposite of the previous noise this was loudest at idle and went away with rpm rise. Had to remove procharger head to remove belt. The numbers were nearly rubbed off the belt so the great search to match it up began. Finally got it at napa and reinstalled. Just started car and let warm up to operating temp and all quiet now. So it's in a state of not being broken again until I run it, move it, or look at it to long again
Try my solution: don't drive it and it doesn't break!
mark
