Results 1 to 7 of 7
Thread: Head bolt problem, need suggestions
    I'm too upset right now to go into details, but here's the problem. I am now running AFR165's on my dart shortblock that has 1/2" head studs. The problem is the head bolt holes in the 165's are 7/16" thus they do not fit. These 165's are just a temporary fix, and they will be going on a stock (7/16") shortblock next year. What do I do??? I did a quick search on ARP's site and I didn't see a reduction style bolt to solve this problem as most people are doing the opposite and running 1/2" hole heads on 7/16" stock blocks.
    Hey Paul, I'd give ARP a call. That would be a major PIA if you had to enlarge the holes in the heads to accomodate the 1/2" bolts. Maybe they do some kind of stud that reduces down to alleviate the issue your having.
    Joe
    Joe
    Joe, that's exactly what I want to do, but I didn't see such a stud on their site. I will call them tomorrow. :(
    Power Adder
    236
    From what I understand you have to drill them out. That's what the directions on my trick flow heads told me to do if I install them on a dart block or R block. Then when you go back to using the heads on a stock block you have to buy bushings ARP sells to fill in the gaps.
    Chris Kauffman
    1988 408LX drag car
    Performer Ford
    Performer 50-state street legal heads provide outstanding bolt-on performance for 1965-95 289, 302 and 351 Windsor V8s. Capable of 300+ hp, the 1.90" intake valves are for use with stock pistons and the high-flow 2.02" intake valves are for use with aftermarket pistons notched for valve clearance. Will not accept rail rockers. Ford 289-302 V8s require Head Bolt Bushings.
    here you go i knew i heard of this before
    i have had to drill out many head bolt holes for 351w or dart blocks... just take em to yor local machine shop and they will know what to do...
    Thanks guys! I took them to my cousin's machine shop and drilled them all out to 17/32" per AFR's recommendation. I quickly tried putting the head on and it worked. I'll have to wait until my daughter goes to bed before I can really test things out.
  1. Suggestions
    Last Post: 03-07-2011, 08:31 AM
  2. Suggestions Please!!
    By Projectcobra97 in forum SN95-New Edge
    Last Post: 04-09-2010, 02:19 PM
  3. took head off 2.3t,needs head and block
    Last Post: 10-18-2008, 07:19 PM
  4. I need suggestions.
    By 2001GTTT in forum General Tech
    Last Post: 04-04-2008, 10:47 AM
  5. suggestions
    By White5.0 in forum Fox-SN95
    Last Post: 02-12-2007, 12:12 PM
