Results 1 to 18 of 18
Thread: 351w carburetor
    Jun 2008
    Level Green, PA
    963
    351w carburetor
    So I just got a killer deal on a 750 double pumper for $125.00. My question is I just ordered the Big Mutha Thumpr comp cam kit for my 351w. Is this carb going to be too much for this set up that it will not run correctly or just cool to use until I do end up with more upgrades. Thank you in advance.
    Sent from my SAMSUNG-SM-G925A using Tapatalk
    Magnaflow Magnapacks Catback
    UPR O/R X-pipe
    Senior Member Dan B.'s Avatar
    Armagh, PA
    4,331
    I have a 750 vac adv on my 387W and had to jet it down.
    Ahh fuque
    1986 Ranger--2WD, 5.0/T5/8.8.
    Jun 2008
    Level Green, PA
    963
    Just ordered jets!
    UPR O/R X-pipe
    Yep - I agree you'll have to jet it down. Nice buy though!!
    You'll be fine. You might need to tune it a little, jets, squirters/nozzles, air bleeds, but it should be good. Which cam, I saw 6 for the 351 on Comp's site? What carb, and how fresh is it? If it was not on a running car in late 2015, if it was me, here is what I would do to freshen it up:
    * Replace pump diaphragms
    * Replace floats
    * Clean out the bowls while floats are out (using carb cleaner)
    * Clean out needle and seat (using carb cleaner)
    * Blow out air bleeds (using carb cleaner)
    * Check what jets are in it
    * Check what nozzles/squirters are in it
    Better to do that up front and have a good running carb, rather than chasing it after it's on. Gas sitting in the bowls can chew up the floats (causing a hole, float won't rise), and diaphragms (they'll leak on the the intake), gum up the needle and seat and air bleeds.
    This kit has a good bit of what you'd need: http://www.summitracing.com/parts/hly-37-485/overview/
    Floats: http://www.summitracing.com/parts/hly-116-3/overview/
    ChuckT
    Sponsored by
    Millerstown Pic A Part
    Jun 2008
    Level Green, PA
    963
    * Replace floats
    Kid bought it new ran it 3 weeks on a firebird. Sold the car kept the carb and sold it to me for rent money.
    UPR O/R X-pipe
    Jun 2008
    Level Green, PA
    963
    This is the carb
    UPR O/R X-pipe
    Member Mark Aubele's Avatar
    Trafford, Pa
    2,308
    That doesn't look like a 4150...
    2014 M235i (wife's)
    1964 Ford F-100
    Jun 2008
    Level Green, PA
    963
    Great!!!! So what did I get?
    UPR O/R X-pipe
    Jun 2008
    Level Green, PA
    963
    Numbers on the side are 12R-10552B
    UPR O/R X-pipe
    Trafford, Pa
    2,308
    Think it is a 4010 series. I know nothing about them. Not your standard "Holley double pumper".
    2014 M235i (wife's)
    1964 Ford F-100
    You should be able to find what model that is. My car isn't home but that looks nothing like my double pumper.
    Jun 2008
    Level Green, PA
    963
    Everything I find says 750 double pumper
    UPR O/R X-pipe
    Wow that is an old carb. That is a 4010 series with mechanical secondaries. Holley hasn't made them in a long time. Think they came out in early 90's. Had one that was 600cfm. Jets are in bottom floor of fuel bowls. Two piece carb sort of like an Edelbrock. Never really had issues with it from what I can remember.
    Jun 2008
    Level Green, PA
    963
    That's what it is
    UPR O/R X-pipe
    Ok, that makes sense. I couldn't come up with anything on Holley's site on the part number 12r-10552b. Summit's brought up rebuild kits only.
    Chargin - you may want to consider spending $1.90 on this :)
    http://www.amazon.com/Holley-4010-40...ds=Holley+4010
    ChuckT
    Sponsored by
    Jun 2008
    Level Green, PA
    963
    Oddly enough I just purchased a fast efi system today. Oh well
    UPR O/R X-pipe
    Oh very nice. I've been looking at the FiTech setups.
