Results 1 to 13 of 13
Thread: Weldon 1100A
    Apr 2011
    youngstown, oh
    47
    Weldon 1100A
    Selling my Weldon 1100a fuel pump I mounted it but haven't run it at all no fuel ran through it or even wired up. I built a new motor before running and now will need a bigger pump. Asking $350
    Weldon 1100-A Flow Though Fuel PumpPerfect Fuel Pump for Higher Hosepowered Street Rods, Muscle Cars, Imports & Extreme Off-Road Vehicles - Anything that requires the maximum fuel flow with quiet and consistent fuel delivery!
    Maximum HP:
    1100hp Inj / 1300 hp Carb
    GPH/PSI Range: 135 GPH / 0-95 PSI
    Considerations: If your actual horsepower is close to the Max HP limit and/or you are considering a power adder, See Part # DB2025-A
    Features:
    * Extremely quiet
    * Smooth, precise fuel delivery
    * Extremely low current draw
    * Self Priming
    Pump may be mounted above fuel cell
    vertical or horizontal mount
    * All internal wear components are 100% metallic
    No plastics or composite materials are used in the 1100-A pump. This results in the longest lasting, highest quality, most durable flow through pump available.
    * The housing is made from corrosion resistant 304 brushed stainless steel
    * Mil-Spec Clear anodized billet end caps with No-Leak seals and stainless steel electrical connectors
    * -10 inlet & outlet with leak free o-ring ports
    * 6.25 lbs
    * Two stainless steel T-bolt style clamps included with each pump
    * Long life, continuous duty
    Current Fluids
    Compatible with Gasoline
    Comments: Requires appropriate bypass regulator, a -6 return line is recommended.
    Do you have the spec sheet for this?
    South Hills, PA
    4,052
    Good seller. Rob ill text u matts #
    Apr 2011
    youngstown, oh
    47
    I'll post it up after work today.
    I'll probably take this.
    Apr 2011
    youngstown, oh
    47
    I added their basic info about the fuel pump and I found the pump test that came with the pump let me know if that's what you were looking for if not ill get any other information from Weldon needed.
    Apr 2011
    youngstown, oh
    47
    Quote Originally Posted by TooFast98Cobra View Post
    Thanks Bill
    South Hills, PA
    4,052
    Sending it now. Sorry work is busy currently
    If you want to do 350 to my door, I'll take it.
    Apr 2011
    youngstown, oh
    47
    If you send payment through PayPal as a gift that's fine unless you want to cover the fee or a postal money order.
    Quote Originally Posted by gerbenitz View Post
    I'll text you in a bit. A gift is fine.
    Apr 2011
    youngstown, oh
    47
    Email is mbusch84@ymail.com text me if you want 3305408335
    Apr 2011
    youngstown, oh
    47
    Still for sale
