Results 1 to 12 of 12
Thread: Hypothetical engine build--opinions wanted
    Parameters:
    1. Engine displacement limited to 8.2"-9.5" Ford Windsor combinations
    2. Natural Aspiration
    3. Hydraulic roller (off the shelf/custom)
    4. Pump gas
    5. Shift point max. rpm under 8,000 rpm
    6. 550 FWHP minimum output
    7. Vehicle weight with driver 2,900 lbs.
    8. EFI
    9. *Should* propel said weight to 133-135 MPH and be capable of bottom 10 sec. e.t's.
    What would you use...
    Cubic inch:
    block:
    crank:
    rods:
    pistons:
    cylinder heads:
    camshaft:
    intake:
    throttle body:
    M.A.F.(if used)
    headers:
    compression ratio:
    max. H.P. RPM:
    cheap route or something that will hold together for a while???
    Good stuff used throughout.
    DART BLOCK
    427 CI ALL FORGED ROT. ASSM
    AFR 225'S
    TRICK FLOW R INTAKE
    B- CAM
    Parameters:
    Cubic inch: 346ci
    block: GMPP
    crank: Stock
    rods: Stock
    pistons:Stock
    cylinder heads: LS6
    camshaft: T-Rex
    intake: FAST
    throttle body: FAST
    M.A.F.(if used)
    headers:SLP
    compression ratio: Stock
    max. H.P. RPM: 730 @ 7400
    Hey...I finally beat Quik once!!!!!
    Huntingdon PA
    1,136
    DART BLOCK
    AFR 225'S
    TRICK FLOW R INTAKE
    B- CAM
    B CAM????????
    709RWHP/750RWTQ
    Hi I'm Stupid 393rag's Avatar
    FayetteNam
    889
    Cubic inch: 393
    block: Dart
    crank: Eagle Forged
    rods: Manley H Beam or Eagle H Beam
    pistons: JE Forged flat tops
    cylinder heads: Edelbrock Glidden Vic Jrs
    camshaft: A big solid roller, like .670 lift range
    intake: Victor
    Carb: 950 Holley Dominator
    headers: Kooks stepped 1-7/8"
    compression ratio: 10.5:1
    max. H.P. RPM: 550-600 rwhp
    Cubic inch: 346ci
    block: GMPP
    crank: Stock
    rods: Stock
    pistons:Stock
    cylinder heads: LS6
    camshaft: T-Rex
    intake: FAST
    throttle body: FAST
    M.A.F.(if used)
    headers:SLP
    Parameters:
    C'mon, no Bowtie engines.
    Charleston, WV
    46
    Dart blocks for 600hp? Thats some serious overkill.
    A seasoned 351W is good for 800hp+ reliably.
    More combos welcome....
    Cubic inch: 427 or 364 if you want to maintain the 8.2 block
    block: dart
    crank: scat 4340
    rods: scat 4340 h-beam
    pistons: JE flattops or domed for high compression
    cylinder heads: Trick flow high ports
    camshaft: Camshaft Innovations (Jay Allen)
    intake: Custom sheetmetal upper on a holley lower
    throttle body: 90mm
    M.A.F.(if used) sct 2800
    headers: Kooks 1 7/8 stepped
    compression ratio: 11.5:1 - 12.0:1
    max. H.P. RPM: ???? @ ????
    Member mlowry1260's Avatar
    Caledonia, Ontario
    620
    Cubic inch:438
    block:dart 9.5
    crank:4.1" forged
    rods:6.2"
    pistons:JE, Diamond or Ross
    cylinder heads:CHI 225 3V
    camshaft:custom
    intake:CHI
    throttle body:105mm or 4-hole
    M.A.F.(if used)standalone, SD
    headers:2"
    compression ratio:11 to 1
    max. H.P. 700+ RPM:7000
    Ex.
    427 cid (675hp) / 440 cid (700hp) / 460 cid (725hp) Running 91 octane pump gas
    AVAILABLE W/ HYDRAULIC ROLLER OR SOLID ROLLER• DART BLOCK CNC PREPPED BY MME• MME CUSTOM ROLLER CAMSHAFT• SCAT/EAGLE CRANKSHAFT• DOUBLE ROLLER CAM THRUST PLATE• SCAT/EAGLE CONNECTING RODS• CHROME MOLY PUSHRODS, 1 PC.• MME CUSTOM ROSS PISTONS & PINS• COMP ULTIMATE ADJUSTABLE TIMING SET• TOTAL SEAL PLASMA MOLY RINGS• BILLET TIMING POINTER• CHI 3V CYLINDER HEADS w/ MME porting
    assembled w/ MME speced, severe valves & valve train • MOROSO OILPAN & PICK UP• COMP CAMS ROLLER ROCKERS• MELLING OIL PUMP• CHI DOMINATOR INTAKE MANIFOLD• ARP O.P. SHAFT• BILLET ALUMINUM VALVE COVERS• ARP HEAD STUDS• BILLET SFI HARMONIC BALANCER• MME CUSTOM COMP LIFTERS & TIE BARS• PRO SYSTEMS CUSTOM HP CARBURETOR• Moroso Oil Pan• KING PRO SERIES ROD, MAIN & CAM BRGS• GASKETS, incl. COMETIC HEAD GASKETS• MSD DISTRIBUTOR & HIGH PERFORMANCE WIRES• ALUMINUM HI FLOW WATER PUMP• DYNO DOCUMENTED, READY TO RUN
    http://www.mmeracing.com/mmeracing/p...p?product_id=1
    You didn't mention price!
    800 hp long term in a stock block?
    Mark Lowry
  1. your opinions on engine (stroker) plans....
    By stangr6man in forum Fox-SN95
    Last Post: 11-19-2010, 08:00 AM
  2. engine build ideas
    By Inkdcountryboy in forum SN95-New Edge
    Last Post: 12-20-2008, 03:20 PM
  3. engine opinions
    Last Post: 05-25-2008, 11:01 PM
  4. Engine Build ideas
    By HidalgoGT in forum Fox-SN95
    Last Post: 03-16-2008, 07:17 PM
