Results 1 to 5 of 5
Thread: 2000 Supercharged GT/Cobra *MINT*
    Purchased a new car so up for sale is my 2000 Ford Mustang GT. Mods include Vortech V1-T supercharger, Snow Performance meth injection, Anderson powerpipe, C&L plenum and throttle body, K&N valve cover breather, 42lb injectors, 90mm MAF, Mcleod clutch, FRPP aluminum flywheel, Bassani catless X-pipe, Magnaflow 2.5" exhaust, KYB AGX adjustable struts, Tein springs, upper and lower control arms and subframe connectors, FRPP 4.10's and rearend cover, Steeda Tri-ax shifter, Hurst knob, Autometer gauges, Cervini's cowl hood, 99-01 Cobra front bumper and fogs, Mach 1 chin spoiler, cobra grill and fender emblems, SVT trunk badge, white Saleen wheels, SCT tuner with 3 tunes, etc. Im sure there are a few things i forgot. The tires have less then 1000 miles on them and are like brand new. All brakes and rotors also have very low mileage and are like new.
    The
    car was tuned by DGR in Dillsburg, it made 420whp 400ft/lbs @ 11psi. It drives like a stocker until you put your foot in it, very smooth and driver friendly, no hiccups. The car has 105k miles, it was supercharged at 86k, runs strong and pulls hard. There is zero rust anywhere on this unit, it was a southern car for the majority of its life, underside looks as good as the outside. Everything works on the car just as it should, super reliable and needs nothing. Averaged 23.9mpg on long trips! The car is super clean inside and out as you can see by the pics, you will be hard pressed to find one taken better care of. The Sparco buckets have been removed since the pics and the stock black leather interior put back in the car. The stock leather interior is mint.
    $10,900
    03 Cobra 10th Anniversary
    70 Nova SS
    So what's the new toy?
    Terminator :)
    70 Nova SS
    Pics and info or ban! Track day???
    She's not pic ready yet, soon. I cant leave anything alone haha. Hoping to have everything buttoned up and finished for the track day in October. As of now it looks like it shouldn't be a problem, making good progress.
    70 Nova SS
