chuck did a great job on the mic
I went from 119 in the right to 122 in the left
I ran 112-114 in 3 runs on the left ( 12.76, 13.1, 13.2 ) and all 3 in the right were between 110.2 and 110.6 ( 12.99, 13.0, 13.05 ). Seems like you're onto something Joe. I did, however, run it past the traps on my best run (left lane), just barely touching the damn limiter. Can't wait to tune that thing out!
Definitely tuning it. Exhaust of some sort will happen - just not sure if I will go cat-back or axle back. Borla S-types either way as I love how they sound. Doubtful on headers unless I find a great deal and even though not sure if the gains will be worth it for such a mild build. I'm not going E85 - just good old premium 93. I need to start a thread of my own for these upgrades.
odd man out. I saw no difference in et or mph right lane to left ???
Uhhhh...didn't you only make one pass?
its all about the front end of your car ....
Most of the summer I was dead even both lanes. I dropped the nose of my car 3/4" to move some weight, and the left lane is faster MPH. Some combination of your nose height, the bumps in that lane, etc. will let your air dam / air deflector / or lower trim trip the MPH clock in that lane. The finish line seems not to be affected.
I agree with Bob to a point about more mph in the
left lane, but think it is the finish line light that is
the problem. At the speed I go through the lights
a car length is about half a tenth, so the foot or
two between the air dam & your front wheels
would mean what? half a hundred? But that
0.005 of a second deference between the mph
clocks might make the couple of mph deference.
If it was the first mph timer at fault the mph
would be slower. And who notices a 0.005 change
on their et but a super bracket racer.
Rodeheaver's Hot Rod Shop
15 W. Cross Ave.
Masontown Pa. 15461
724-737-5088
www.RodeheaversHotRod.com
Details on the 12.40's SUV?
A little late. But great track rental. Had a lot of fun and was able to make good passes on the car. Made a lot of passes to keep getting this suspension dialed in. Thanks a lot and hope to do it again! Went 11.58 @ 119.
2000 Camaro - Cam only on a diet 11.38 @ 120
