Results 1 to 19 of 19
Thread: What's up with teh burning oil smell on these 4.6s?
Hybrid View
    5,822
    Question What's up with teh burning oil smell on these 4.6s?
    My other car did the same thing and I thought it was just fuggered up. Well, this '01 does the same thing. I think I've narrowed it down to the cheap rubber elbow that comes off the front of the plenum, makes a 90* bend and goes back into the PCV Valve on the passenger side head. After a drive, it's somewhat mushy to touch it. Is there really that much oil coming out of that valve and into the intake. The other car never used any oil between changes and this one seems fine so far.
    There are no other leaks anywhere. WTF? It just drives me nuts.
    2019 Colorado ZR2
    Fuwkawee
    5,151
    Its called your beaten the snot out of it. I never smelled it when I had it.
    17 Ram 1500 Big Horn Hemi
    16 Comp O GT Performance Pack
    Mine is noticable when I run an off road pipe. As Frank Tedesco up at PRP made a comment to me last year about smoke from one tail pipe when launching. Both my 2000GT and my current 2004GT have done this. Doesn't seem to use much oil when it happens as I never really need to add anything when I check.
    I run a catted pipe now and it is not noticable. The biggest thing is turning the high rpm's and the cams are creating a nice oil mist in the valve covers which easily gets pulled thru the pcv system. I picked up and air/oil seperator from Jegs that I plan the use to keep any further oil from being pulled into the intake system and then burned off. Not good for making power if oil is burning. My spark plugs seem to stay clean so I know it's very little being burned off.
    5,822
    thanks, Ares. Are you going to put the a/o seperator on the PCV hose on the pass side or driver's side? or both? and where are you going to mount it. I would think somewhere on the firewall, but these damn things got so many hoses running around it looks like chit as it is.
    2019 Colorado ZR2
    Somerset Co.
    2,907
    Must be a GT thing
    5,822
    Must be a GT thing
    uh huh so my GT costs 1/2 what your Cobra does and it makes 1/2 the hp your Cobra does... how come your Cobra doesn't run the quarter in 1/2 the time? lol lol lol j/k
    2019 Colorado ZR2
  1. Global Economy = teh raep!!!1!one!1
    Last Post: 04-22-2009, 05:16 PM
  2. Im burning 2 much oil. + Maintenance help
    By Knapper411 in forum General Tech
    Last Post: 03-06-2008, 11:49 PM
  3. TeH sRt CaN nEvAr LoEs !!!1111BBQ!1111
    By Cam99 in forum The Bar
    Last Post: 09-02-2007, 07:56 PM
  4. teh 5.0 is running like crap
    By J-rod in forum Fox-SN95
    Last Post: 05-04-2007, 08:17 AM
  5. why does it smell like grape??
    By madmaxin22 in forum The Bar
    Last Post: 03-29-2007, 10:33 PM
