Results 1 to 3 of 3
Thread: Flywheels
    U.S. Citizen 86GT's Avatar
    Sep 2011
    Monroeville
    323
    Flywheels
    I was hoping some of you guys would care to share
    their thoughts concerning aluminum vs. steel flywheels.
    I have an aluminum one now (spec) in my fox & have
    done my best with it at Keystone, but might steel be
    better for drag racing?
    Lil' Blackie, also a Rodeheaver hot rod
    Black Bess : n/a 347 T56 magnum,426 hp/ 427 tq
    Best time at Keystone 11.68, best speed 122.95 mph (right lane)
    Built, tuned & made possible by Tim Rodeheaver
    Rodeheaver's Hot Rod Shop
    15 W. Cross Ave.
    Masontown Pa. 15461
    724-737-5088
    www.RodeheaversHotRod.com
    Robinson Twp.
    2,143
    I'd say it depends on your suspension. If you're launching off the limiter and still dead hooking then a switch to steel might be worth while to be able to leave harder. If not, then there's probably no need to switch. It's all about momentum. An aluminum flywheel at 6000 RPM will be similar to a steel flywheel at say 4500 RPM. I don't know what the exact difference is, but that's the basic idea.
    2015 Charger Hellcat
    85 GT
    73 F250
    Lifted, 35's, 460 4spd
    Real name = Ray
    I switched from a steel to lightweight aluminum in my 2000 GT. A lot of people said it would hurt my 60' time because of the lighter weight and less rotational mass momentum during the launch. But it didn't, my 60' stayed the same. I couldn't say if it helped on the top end because I did a few other mods at the same time. It definitely allowed the engine to rev quicker, no complaints here with the aluminum. I would stick with what you're running now.
    03 Cobra 10th Anniversary
    70 Nova SS
