Going to be a very cool build
It really is a sharp car - almost too nice to mess with. But it sure will be badass when its done!
I believe CANBUS started with the E46, so '99? I know some of the kits had booster interference, but I don't think this one does. The engine sits low and it is moved towards the pass side to clear the ABS (which I am keeping).
Thanks. I am going to try and clear out my phone and start getting some pics up. Finally brought motor and trans home today. Diamond stage 3 clutch setup will be here in a few days, cam and harness won't be ready until the 29th.
Thanks Ron. But you saw it, it's nowhere near as nice as it looks in pics. Spotless underneath which is why I bought it but like 3 different shades of blue :)
2014 M235i (wife's)
1964 Ford F-100
Yeah but all nice shades!
I love the e36 M3 sedans.
Alright. Finally got some parts in and my buddy got the harness done, so started the party this past week into the weekend. Removed front clip, pulled BMW engine and trans...
While I was pulling it, got rid of all the AC BS and some wiring. Still a bunch to do with that, will wait until I get the LS in to get rid of anything major. Wasn't bad getting it out, managed to only cut a heater hose my dumbass forgot to disconnect before I had the whole thing hanging from one incredibly shitty Harbor Freight strap.
Pics of header and Diamond Stage 3 clutch..
Couple friends came down from around Philly for our halloween party and brought some goodies. LS harness with bullshit cut out and TSP Magic Stick 4 cam. I bought TSP springs, Ti retainers and pushrods. We got to work swapping everything over..
Was too lazy to pull the heads and didn't want to try the Russian Roulette method of spinning the cam and hoping the lifters didn't fall into the pan, so we turned it upside down.
More ghetto shit, motor is setup for a LS1 manifold so the ribs on the bottom of the LS6 manifold hit the steam tubes, took care of that issue too...
2014 M235i (wife's)
1964 Ford F-100
Got everything together, started putting the harness on the engine/trans. He labeled everything so even I couldn't screw it up. Should only be 4 or 5 GM harness to BMW connections I will have to make. Should be dropping it in this weekend. Still have to order O2 sensors and some other random stuff. Rest of fuel system parts should be here tomorrow. Running C5 regulator/filter combo, -6 AN up to rail, 255lph in tank.
Cleaned up a bit underhood. Not painting it, because I really don't care enough to. It looks good enough for now.
Before
After
Looks pretty much the same. Stay tuned, should have it sitting in the car this weekend. Hopefully running in a few weeks. Need to decide whether to have it mail order tuned or buy HPT and do it myself. Time wise will likely do the mail order thing. Pretty common setup.
2014 M235i (wife's)
1964 Ford F-100
Looking good Mark. That power to weight ratio is going to be fun.
2014 M235i (wife's)
1964 Ford F-100
I bet she has a little Hitler 'stache...
Well, I realize this is the shittiest build thread in history so far, but I will ad an update anyway. I promise I will make up for it with plenty of track and hillclimb videos come springtime.
Last weekend got the engine and trans in.
The fit of the motor and trans mounts was acceptable IMO for how cheap this kit is. The oil pan is really close to the k member, so it is low as can be which I am happy with. This kit is marketed to clear the abs lines, which is the main reason I went with it. Didn't clear them at all...
Took that picture after I had lowered ABS unit around 2". Ended up working perfectly. Lines are as far away as most I see with relocated units, will cover lines and unit with heat shield or wrap headers after I get car back from cage guy. Have to get this thing running and interior gutted by mid december so the fine tuning stuff can wait. Picture also shows primary very close to coil pack, will likely just space up a bit and toss a 90 degree boot on. Other than that the headers went in very easily. Close to trans, but it all looks like it will play nice with each other.
2014 M235i (wife's)
1964 Ford F-100
The valvecovers are also really close to the brake booster. Looks like it won't hit. Trans is also touching tunnel in a couple places. No biggie, will clearance it later.
No picture of it, but got my JTR flange in, allows me to use 1310 u joints front and rear. Having custom driveshaft made. They sell them for the swap but they are like $700. No thanks.
Also stuck a 255lph pump in the tank.
Got tired of being covered in 20 years of Kraut leakage, so moved on into interior removal.
This was just was under the rear seat. Consistently amazed at how heavy BMW interior shit is. Every little piece I touch seems to weigh five pounds.
Started removing tar paper from floor, came off the floor from rear seat area rearward like this by hand...
That party ended pretty quickly. It got harder as I went forward.
2014 M235i (wife's)
1964 Ford F-100
Millernaught stopped by last night, we pulled the sunroof out...
And started removing more difficult tar paper...
Not sure what kind of weight I'm going to drop removing it, but the garbage can is getting heavier and the car is sitting higher and higher. Car was just over 3200 before I started all this with 1/2 tank of fuel. Planning on weighing it before it goes in for the cage. Trying to keep cage as minimalist as possible while staying legal.
Gonna bet fuel system buttoned up this weekend, get steering shaft in and some other odds and ends. Hopefully figure out wiring (not my forte) next weekend and start this thing in a couple weeks.
2014 M235i (wife's)
1964 Ford F-100
cool build every little bit helps my coupe looks like a 4 wd with all the weight I have taken out of it so far
This build thread would be a helluva better if that dog is a husky and you post more dog pictures.
Just saying.
Additionally, as a long-time Ford & BMW enthusiast, I must say this Chevy-powered bastard you're building is really cool!
Huskies are great dogs and I'll never have anything other than one.
You need two. These ****ers are nuts until you have two or more of them.
2014 M235i (wife's)
1964 Ford F-100
Shit Mark - how nuts was yours until #2 arrived? Gorgeous pups....but a tad intimidating!
