Results 1 to 8 of 8
Thread: Kudo's to Holley's customer service
    Bought a C-list carb that looked to be near new. Guy claimed it worked well on what it came off of. (right)
    Pulled bowls off to check jet sizes - found the carb coating flaking off inside the carb on the metering block and bowl. (mostly block)
    Well that's no good...thinking about giving that fine gentleman (also did not see until disassembly that some gorilla tightened the idle mixture screws so tight they cracked the metering block) a call back but then thought...this seems like a clear manufacturers' issue.
    So a little internet search showed of course there was brief window of time where the coating was an issue and Holley was replacing carbs no questions asked.
    The interesting part - this was 2005/2006 time-frame.
    Anyway called Holley tech - gave them build date and they confirmed it fit the bill for a free replacement....on a 10 yr old carb.
    That is good customer service.
    Brookline
    2,897
    That is the way it should be. Their minor loss on sending a new carb out for free is long forgotten when said customer shops again and possibly tells their friends.
    charleroi
    478
    Nice. I agree that is how it should be. There almost guaranteed to get repeat customers and good reviews which go along way in my opinion
    where do the injectors go ????
    Senior Member Dan B.'s Avatar
    Armagh, PA
    4,331
    Did you specify a high MPG carb?
    Ahh fuque
    1986 Ranger--2WD, 5.0/T5/8.8.
    in kind replacement only.
    The injectors dribble alot....like all the time...i think something may be wrong.
    I was going to point out that it was still a carb, and like having a broken clock ... right a couple of times a day :D
    Polar Vortex
    6,031
    That's just good/smart business.
