Page 3 of 5 FirstFirst 12345 LastLast
Results 41 to 60 of 85
Thread: Project parts swap.
  1. #41
    Looking good man nice work.
  2. #42
    charleroi
    478
    Thanks man appreciate it been just chipping away at it whenever I can.
  3. #43
    charleroi
    478
    Wire tuck time man this sucks lol.
  4. #44
    charleroi
    478
    We're a are u guys mounting ur fuel psi regulator on a carbed fox? It was mounted on the pinch weld of the fire wall on the other car but I'd like to make this car legal as I go. Thanks in advance for any advice.
  5. #45
    Jan 2011
    Allison Park, Pa.
    366
    Mine is mounted on the back side of the passenger shock tower. It passed tech @ Norwalk. No one has ever questioned that location. My Carbed Fox 408 Windsor runs my new best @ 10:28 @ 131 MPH.
  6. #46
    charleroi
    478
    That's were I'm thinking also. Just don't really like routing the fuel lines over the down pipe but that seems to be the best place and I'm pretty sure the way the rule is stated it's completely legal. Thanks for the reply.
  7. #47
    You should be good there. Go to page 54
    http://www.ihra.com/images/2017_Spor...rulebook_2.pdf
    ChuckT
    Sponsored by
    Millerstown Pic A Part
  8. #48
    FUEL SYSTEMS: Whenever possible, fuel tanks and fuel lines should be located ahead of the engine. Fuel blocks, if used, must
    be mounted at
    least 6” forward of the flywheel bellhousing area. No part of fuel system may
    be mounted on the firewall except fuel pressure regulator or
    isolator or fuel block. It must be mounted as far away as possible from the flexplate/flywheel area.
    ChuckT
    Sponsored by
  9. #49
    charleroi
    478
    Getting ready to start the fuel system. I have all the lines left over from the vert it's all Summit brand push lock. Would u guys reuse it or switch to true an line? I built the vert when I was broke hence the push lock but I never had a problem with it just wondering if I should take this as a good time to upgrade?
  10. #50
    Jan 2011
    Allison Park, Pa.
    366
    I would do the upgrade. I've had some problems with Summit brand products. Better to be safe than sorry.
  11. #51
    Is this race gas only, any pump gas or E85?
    that likely answers what you need to use. If race gas only,you may be fine.
  12. #52
    charleroi
    478
    Pump gas for the street race gas for the track no e85
  13. #53
    With Pump gas and it’s ethanol, I’m not sure that anything not Teflon lined is a good thing. Have had several friends use the rubber lined hose with pump gas and ended up with fuel smell in their garages and trailers. I went with rubber lined hose because I only planned to use race gas. Last year full season and no issues.
  14. #54
    charleroi
    478
    Ended up scrapping the push lock after some inspecting it's so stiff and brittle it cracks when u bend it at all. So will be ordering new an line and fittings tonite.
  15. #55
    charleroi
    478
    Coming along
  16. #56
    Are you going to finish off the paint with the fenders?
  17. #57
    charleroi
    478
    Yea whenever the last guy did the engine bay the used the fender crease as a tape line and did the edge of the fender black for whatever reason. I just put them on to fit everything up and what not. Will be spraying that b4 the car is out. Been chipping away at it a little at a time. My son wrestles so don't have much time u till the season is over.
  18. #58
    charleroi
    478
    I still need to finish up the rad hold down aswell. It's stainless from were I work but must be super low grade bc it is getting surface rust on it.
  19. #59
    Looking great! My god I need to get to work.
  20. #60
    Quote Originally Posted by black 94 View Post
    I know exactly what you mean. Time is hard to come by. My son used to wrestle. Ha hasn’t for the last 2 years. It occupies a lot of time.
    Where does yours wrestle at? Our season here just ended and wawa was last weekend.
