Page 3 of 4 FirstFirst 1234 LastLast
Results 41 to 60 of 71
Thread: Winter Upgrades
  1. #41
    does it run 32psi on pump only no meth?
  2. #42
    Mar 2009
    South Hills & Washington
    863
    32 on E. Around 26 on 93.
  3. #43
    it's soo-tack sutyak's Avatar
    Fairmont, WV
    2,467
    What RPM are you spinning the EVO to? At least we can guesstimate on the numbers!
  4. #44
    Mar 2009
    863
    Valvetrain is built for whatever I want to throw at it. However, the turbo I have on here starts losing efficiency at 7500. I'm seeing full boost at 4K. More seat time is needed to see what the car likes.
  5. #45
    Mar 2009
    863
    First cold start on build and Basemap. Crappy vid, but you can hear some of the cam lope.
    https://youtu.be/c9_Niuh2wbI
  6. #46
    Mar 2009
    863
    *edited. Damn auto-correct on this phone
  7. #47
    Mar 2009
    863
    A couple test hits to check Afr
    https://youtu.be/nmfhSaREykU
    Sent from my HTC6525LVW using Tapatalk
  8. #48
    Looks like a fun car David!
  9. #49
    Fairmont, WV
    2,467
    I love a turbo so much.
  10. #50
    Mar 2009
    863
    Installed coilovers yesterday, then drove over to my tint guys house to have the windshield re-done. (Because I know you guys love that)
  11. #51
    South Hills, PA
    4,052
    U just tint over the stamps? I had a square cutout. I didnt know what to do. I almost just scraped them and sell hell with the stamps.
  12. #52
    Mar 2009
    863
    Yes I usually have him go over the inspection stickers. When it's time for inspection, I get the steam gun out and remove the tint. I have had a box cut before, became a hassle when putting the inspection stickers back on.
  13. #53
    Looks good man!
  14. #54
    Mar 2009
    863
    Looks good man!
    Thank you. Did you put the vmp tvs on the GT500?
  15. #55
    Quote Originally Posted by 1320goat View Post
    Yep, it's on. Still need to work with Lund to get it tuned though. Hoping that goes well and we don't find any mechanical problems along the way
  16. #56
    Mar 2009
    863
    Very nice. I think you'll be happy with it. Lund tuned my tvs car and it was spot on
  17. #57
    Getting closer, engine back together less my upper intake ... 10,000 little things left
  18. #58
    Senior Member Dewayne's Avatar
    Feb 2015
    Clarksville PA
    180
    Sooooo, I have managed to get 8 bed bolts out over the winter. No where near the progress I wanted to have. The engine was about ready to get assembled for the truck, but every crank I get my hands on seems to have some issue.
  19. #59
    Finally found some motivation ....
    new cam installed, hot side refreshed (gaskets and seals), engine stiff done and diaper fitted...
    new fuel system, Walbro 450 pump, Pro M hanger, all AN line to and from rail, wiring upgraded to 10 gauge from the alternator to pump.
    all fresh fluids and mostly ready to fire.
    transmissions are out, going to break them down tomorrow night to go through them both. Also going to have inputs ground to 2.3 diameter so I can go back to a pilot bearing instead of the bushings I've been running.
    upper intake finally mostly done, needs bosses for my throttle cable and a plate I can take for connections, but it's built.
    looking to be running next weekend. Should be doable
  20. #60
    Feb 2015
    904
    Car looks and sounds sick.... What turbo?
    If I was a betting man, I'd say FP Red?
    Best MPH: 132.21
    Best 60' 1.490
