Results 1 to 16 of 16
Thread: 2016 Coyote Oil Separator
    North Hills of Pittsburgh
    430
    Thought I would share this. I installed the Ford Racing oil separator a few months ago when my 2016 GT had approximately 10,000 miles. A few weeks later, I noticed the car felt much faster but wasn't sure why. At 11,400 miles I opened the oil separator for the first time and found 2 to 3 ounces of oil in it. I can only assume the oil was going into the intake and lowering the compression ratio before the oil separator was installed.
    2016 GT Premium
    Thanks Bob - I will be adding one to my '14 this spring.
    NEWB 89stang's Avatar
    North Huntingdon
    1,136
    First thing I got for my 15!
    Guess I need to get me one of those!
    Sent from my SM-G935V using Tapatalk
    Big member venom's Avatar
    North Fayette Township, PA
    1,344
    I have a new Steeda separator sitting around for a 15-17...just saying. :)
    2015 GTPP
    430
    My car feels like it picked up 50 ft-lb of torque after installing the oil separator.
    2016 GT Premium
    Whatcha want for it?
    Jun 2007
    N. Huntingdon
    1,596
    Compression ratio has nothing to do with it. And lowering compression ratio means increasing space in the combustion chamber, not filling it with oil.
    Oil can combust, causing detonation. Bad for n/a cars, very bad for boosted cars. That's why you install an air oil separator.
    Chris
    2016 Chevrolet Volt
    2010 Jetta TDi Cup Edition
    1964 Lincoln Continental
    Senior Member Darren's Avatar
    Jul 2010
    Moon Township, PA
    859
    I have one on the Boss i haven't opened in 1,500 miles...
    -Recaros, Torsen #0054
    -Ford Boss Springs, BMR Upper/Lower Control Arms, Panhard Bar
    -LED Interior Lights, 15% Tint, Carbon Fiber this and that.
    -JLT, Lund nGauge
    2016 Ford Focus ST - Kona Blue - DD
    -ST3, Recaros, Nav, Roof etc
    -Springs, Tint, Mountune Intake
    1983 Black GT Hatch 5.0 - Sold
    2011 Sterling Gray GT - Sold
    2010 Candy Red Metallic GT - Sold
    2004 Competition Orange Mach 1 - Sold
    2000 Silver GT - Sold
    1969 Candy Apple Red Mustang Coupe - Sold
    Not compression so much but the oil lowers the octane of the intake charge, right?
    Funny how my diesel doesn't have this issue. 😎
    it's soo-tack sutyak's Avatar
    Fairmont, WV
    2,467
    It would technically raise the octane rating, since it takes a higher compression to burn oil compared to gasoline. That being said, I highly doubt there is enough oil being added per stroke to significantly change the octane rating. Considering how much water+meth has to be sprayed to raise the octane and get any benefit at all, 3oz of oil over 1,400 miles shouldn't matter much. That's a 1,100:1 mixture of gasoline to oil assuming 18mpg.
    I'm just throwing that out there to say the octane change isn't much of a factor. Obviously burning oil is not going to help the combustion process.
    i have one on my 12 and have emptied it at least twice and it had some in it , so I think its worth while ,
    Troy what kind did you buy? Is yours on the passenger side? I have heard that "Bob's Oil Separators" are better than JLT but I'm curious to hear your thoughts.
    Hahaha. I was thinking the same thing!
    5,822
    just put a JLT on my car two weeks ago. difference in first ride. best 140 bucks and literally 12 seconds for a mod.
    2019 Colorado ZR2
